• 19.11.2026, 23:51
Top_Nurse
Flow meter mods
dimanche 29 mai 2005, 01:11
Greetings most exalted ones...
I have been reading the Digmesa manual on the flowmeter that A-C sells. What happens to the flow calibration if I open up the IN port to the same size as the OUT port? I assume this would make the unit less restrictive, but is it a noticeable gain in cooling ability?
Also does anyone know if you can hook more than one unit up as I am planning two complete separate loops. Is this something that the Multi-Switch can be used with?
Re: Flow meter mods
dimanche 29 mai 2005, 01:52
A few people here did it including myself ;D
It gives a bit better flow. You should change in and out and set the calibration value to 256 imp./min to get a proper result.
You can connect two flowmeters to the Aquaero ;)
Top_Nurse
Re: Flow meter mods
dimanche 29 mai 2005, 02:53
Great! Where do I hook it up to? Perhaps the Aquabus header?
Did you open up both ports or just the IN port? If both what size did you bore to?
Re: Flow meter mods
dimanche 29 mai 2005, 03:01
I opened the in port (~6mm). You connect the second flowmeter to fan connetor 4 and do a little change in your Aquaero configuration ;)
x-stars
Re: Flow meter mods
dimanche 29 mai 2005, 15:16
If you change the input to ~6mm use the output as the input, cause the output is exactly 5,6mm (256 Pulse/L).
I did this with my flowmeter, but I woukldn't do it again, it did not change anything.
Talking about Flow-Meter-Mods: Another thing I made is putting an LED with resitor between Power and Signal of the Sensor: Now the LED blinks on every Pulse :D.
Infiltraitor
Re: Flow meter mods
lundi 30 mai 2005, 00:05
Citation de "x-stars"
What CPU block are you running?
If it's the EVO I think the internal ports are smaller than those on the flowmeter, so your greatest restriction is still there.
Any thoughts/info on that anyone? ???
Top_Nurse
Re: Flow meter mods
lundi 30 mai 2005, 10:52
Citation de "Shoggy"
Cool! You don't suppose that the "New Aquaero" will have more than 4 fan ports do you?
Top_Nurse
Re: Flow meter mods
lundi 30 mai 2005, 10:55
I read the Digmesa manual and it said there is no output power from the flow meter and that it just makes a simple on-off-on signal break. So does this only work when using the fan header 4 mentioned above?
Mr_modnaR
Re: Flow meter mods
lundi 30 mai 2005, 12:33
I would think that it does give out a pulsed voltage, although that may well be below 12V, maybe even 5V. You could attach it to 12V and earth, and then measure the third wire with a multimeter, whilst blowing thru a tube connected to the input (or 'output' if you decide to change them around for the mod).
"I'll huff, and I'll puff, and I'll blow your Aquaero Flow Sensor up to 300CFM!," said the big bad wolf. - excerpt from 'The Three Little Computer Modders'
x-stars
Re: Flow meter mods
lundi 30 mai 2005, 22:14
Yes, two of the Evo 1.1 :).
The Signal is a short connection to Ground on every Pulse, so get the Power (I think the green Cable ob the Ae-Connection) and the Signal and connect a LED with resistor betwen them - the LED works on every Pulse. It will probably work as well on the Sensor-Port as on the FAN4-Port of the Ae :).
Infiltraitor
Re: Flow meter mods
mardi 31 mai 2005, 15:19
Has anyone ever opened up the ports on an Evo 1.1 slightly?
I'm sure larger ports must have been trialled during development, and was wondering what the effect was?
