• 29.11.2026, 19:23
damado
Aquaero not found unless I use aquasuite
jeudi 4 août 2005, 08:39
I cannot do the aquaero OS loader flash b/c it will not find my aquaero. Aquasuite finds it just fine and I can change all settings.
What can I do to allow aquaero OS to find the aquaero?
Edit: I'm mainly trying to flash b/c for some reason ever since my last flash my Blue LED doesn't get any brighter...it always stays a the same brightness level. The red gets darker and lighter just as before. I do not know why this is happening.
Re: Aquaero not found unless I use aquasuite
jeudi 4 août 2005, 14:46
If you can use the Aquasuite right now then you already have the newest OS.
Open the Aquasuite and go to the menu display and hardware. At the bottom you can see the firmware and OS version. The newest OS is 2.03 and firmware is 4.07a.
damado
vendredi 5 août 2005, 06:44
Citation de "Shoggy"
Thanks, I went in and saw that I had 2.03 and 4.05 (I think...it wasn't 4.07). I then flashed it through aquasuite to 4.07.
The problem that concerns me is the brightness of my blue LED in the aquatube. It used to be just as bright as the red...I can make the red brighter or dimmer by a significant amount by adjusting the settings in aquasuite, but the blue hardly changes. Any ideas?
