• 02.10.2026, 05:05
REDG
TwinPlex for AOpen i915GMm-HFS
mardi 6 septembre 2005, 22:03
Hello everyone
To install TwinPlex on a AOpen i915GMm-HFS I think it's necessary to use Blende GeForce 6800 for the processor and Blende Gigabyte for the chipset.
Unfortunately AquaComputer doesn't propose TIFF-Datei for these two "Blenden".
It's possible to realize them easily...
Thank you for your assistance
M'en Bati Sièu Nissart
REDG
Re: TwinPlex for AOpen i915GMm-HFS
mardi 6 septembre 2005, 22:18
Or to realize a sketch with dimensions
Ze@lot
mercredi 7 septembre 2005, 18:45
your gonna have to take a chance on a twinplex fitting your
CPU. this mobo has a bad rep as AOpen used there own hole
placements on this board so none of the aftermarket HFS
CPU coolers will fit. maybe if it does not fit you could make
your own bracket.
imo tho id ditch it and get another board. one that uses
standard hole placements. sorry i cant get any other advise
as im not into micro-ATX boards.
good luck
Ze
REDG
jeudi 8 septembre 2005, 14:49
I think that it's possible...
Chipset : 6.3 cm
Processor : 7.5 cm (5.3*5.3 cm)
If I can have these dimensions...
Nobody have these "Blenden"?
Hummerman
dimanche 11 septembre 2005, 21:24
from A to B 7,50 cm
NikoMo
NikoMod
dimanche 11 septembre 2005, 21:25
hi, the normal twinplex has a hole-to-hole-distance of 62mm. so, he might fit.
REDG
dimanche 11 septembre 2005, 21:53
Citation de "Hummerman"
from A to B 7,50 cm
Thanks ;)
REDG
dimanche 11 septembre 2005, 21:58
Citation de "NikoMo"
hi,
Yes, I think too that it's preferable to use these. 62~63 mm :P
Thanks a lot :D
