• 08.10.2026, 04:10
MUFFDIVER
Temp monitor Q.
samedi 12 novembre 2005, 16:52
ok i have the A8N sli deluxe mobo and want to know what my temps on moard are. What software (freeware ::) ) would you suggest is accurate 99.9% as nothing in computers is ever 100%.
Beun
Re: Temp monitor Q.
samedi 12 novembre 2005, 16:57
Motherboard monitor used to be the best. But it hasn't been updated :(
You could used Asus PC probe, but I'm not a big fan of it...
Re: Temp monitor Q.
samedi 12 novembre 2005, 16:59
There ist no software which could provide you with accurate temperatures. The problem is the mainboard and CPU itself. Their sensors have wide tolerances.
Top_Nurse
Re: Temp monitor Q.
dimanche 13 novembre 2005, 03:09
If you want to know what the temps are then get an infared thermometer and aim it at the part in question as it will be more accurate than the MB sensors. The MB sensors are there pretty much as fail-safe items to keep your computer from going into a meltdown mode. I suppose you could drill your waterblock and insert a NTC thermistor so it is right above the CPU, but that will not give you CPU temps. BTW, why do you care as you can't compare your temps to anyone else's.
MUFFDIVER
Re: Temp monitor Q.
dimanche 13 novembre 2005, 13:33
no i want to check the temp of the north bridge? And + was just a purely intrest thing only? as i want to run the system with the 360 added and check to see if it is worth adding when the system is loaded.
;D
