• 08.10.2026, 12:06
edboswell
connecting usb aquaero
mercredi 14 décembre 2005, 00:51
Which pins do the usb cable go into on my motherboard i have a dfi sli dr on it the usb connector pins go (Standard i believe) -
say * = no pins and / = pin
what should be the correct way (in terms of the colour of wire slotting into the pins) thanks :)
Ed.
MUFFDIVER
Re: connecting usb aquaero
mercredi 14 décembre 2005, 04:00
WUD LOVE TO HELP BUT I AINT SURE? UM TN WHERE R U THIS EVENING?
oops sorry for caps ** 8)
Top_Nurse
mercredi 14 décembre 2005, 10:50
Well I took a spin down to Palm Springs in my Volvo 850 Turbo Sedan so I have been off line for a bit. Who would have ever thought that the car drives better at 100 MPH (160 Km/H) than it does at 70 MPH (113 Km/H)? ???
Attach the red lead (+5v) to Pin 5 on the Tubemeter. Attach the red lead to pin 1 on your MB.
edboswell
mercredi 14 décembre 2005, 22:09
why isn't my aquaero connecting >:( >:( i swear iv done everything right??? shoggy any help as you are the ac gurro ;D
mercredi 14 décembre 2005, 22:49
Compare it with your wiring, you will have to turn the first picture ;)
edboswell
mercredi 14 décembre 2005, 23:20
ok i have done that but it still isn't being brought up in aquasuite :/ is there something else i have to do to enable it. I will try in another usb slot but i dont think theres anything wrong with this one...
mercredi 14 décembre 2005, 23:21
Is this a new 4.00 Aquaero or 3.07?
edboswell
mercredi 14 décembre 2005, 23:26
4
MUFFDIVER
mercredi 14 décembre 2005, 23:40
Are they USB2 or 1.1, probably sounds stupid but just a thought?
8)
edboswell
mercredi 14 décembre 2005, 23:43
usb 2... i thinkkk that maybe theres some jumpers or something to enable these "extra usb slots" because the other one isn't working aswell... i have the dfi lanparty sli dr if anyone else knows whats jumpers to change... im googling atm
edboswell
jeudi 15 décembre 2005, 00:20
it was a jumper problem everything is sorted now :) thanks
Top_Nurse
jeudi 15 décembre 2005, 09:02
Jumpers ??? You mean MB BIOS switches?
edboswell
jeudi 15 décembre 2005, 10:42
hmm i mean there are some pins with a little blue thing (jumper - i think) next to the usb slots within my motherboard... and the blue thing had fallen out - i think it simply lets the usb have power (eg actually operate). So i put it back in and all works... but my lian li case (pc 71) feet have broken now - i think because my case weighs about 50 kg.. so i need to buy new ones.. any people from england know where to buy some that will fit this case (pm me)
MUFFDIVER
jeudi 15 décembre 2005, 22:31
umm try a diy store and get some feet and drill holes to mount them. but some heavy duty 1's like dj's rackmount feet or summin along those lines.
Or summin like this, they will hold 150kg (apperently)
http://www.electroenoc.se/?articleId=263&lang=UK
