• 19.11.2026, 06:00
Preview: System Aerocool Bay Dream
mardi 20 décembre 2005, 15:53
The systems-series has a new member which is based on the Aercool Bay Dream case. It should be ready within the next days.
This case has 10(!) 5.25 slots but is very compact with its small dimensions. As a nice special touch it is compatible to the new BTX standard.
There will be two versions, one with the airplex evo 120 and the other one with the 240. Even with the bigger radiator you are able to use four 5.25 slots in any way you want to. Inside the case you can mount two harddisks.
A special edition of the aquabay in combination with a aquatube acts as the reservoir. The radiator is mounted inside the 5.25 slots which results in an optimal airflow. In this area you can also install a aquaero, a multiswitch or other short panels - there is enough space between these components and the radiator.
A few photos:
Nitrix
Re: Preview: System Aerocool Bay Dream
mardi 20 décembre 2005, 20:31
OMG!
that looks insane!!!!! the only thing that could seriously make that any cooler would be an etch side panel!
MUFFDIVER
mercredi 21 décembre 2005, 21:06
LOOKS NICE! ::)
