• 30.11.2026, 23:16
Sc4mpi
Aquaero relay query?
mardi 3 janvier 2006, 22:50
Hello again, just a quick question....
there is the relay header on the aquaero
1, does the aquaero already have a relay already on it, or do i have to wire one up (i.e is there a relay already on the aquero pcb)
2. if it does have one already on it i presume i can just wire up the contacts on the mobo header so if theres a fault it can trigger a shutdown.
Just want to work this out. thanks again  :) & happy new year
Sc4mpi
Re: Aquaero relay query?
mardi 3 janvier 2006, 22:51
x-stars
mardi 3 janvier 2006, 23:00
It has a relay (oficially for a maximum of 12V@1A) and yes, it's for parallel connecting to the power-switch or in-line-connection of the ATX-Power-Good-Cable (green), so the aquaero is able to shutdown and 'rescue' your PC :).
edboswell
mercredi 4 janvier 2006, 00:49
the cables are veryyyy messy though for this :(
Sc4mpi
mercredi 4 janvier 2006, 03:09
thanks for your help x-stars, got it sorted and wired up andy gave it a test and the emergency shutdown works a treat :)
Citation de "boswell"
??? which cables ed
