• 14.11.2026, 13:48
Isaksson
Connect the aquastream
jeudi 5 janvier 2006, 19:20
Hello.
I have a old aquastream on the front the name is not aquacomputer it says "Mist"
but when i read the manual for it it says that i could connect it to a aquaero and i have an aquaero-bridge connector.
the first time i connect it to my aquaero then the oump just started for like 1-2 sek then turnd of then started again.
so i disconnected it and connected the power back to the aquastream, and then i started the computer and fixed some stuff in aquasuite.
and when i try to use the aquaero-bridge now the pump doesent start at all.
any ides?
and by the way i should not have the power connected to the aquastream when i use the aquaero-bridge, right?
Thanks
Re: Connect the aquastream
jeudi 5 janvier 2006, 20:18
Citation de "Isaksson"
Right.
The Pump or Controller is named "Mist" ??? Can you take a photo? Do you know the version of your controller?
Isaksson
jeudi 5 janvier 2006, 20:31
Hello.
Its the controller that has that name,
here is some pictures
http://213.113.110.198/aquacomputer/1.jpg
http://213.113.110.198/aquacomputer/2.jpg
http://213.113.110.198/aquacomputer/3.jpg
http://213.113.110.198/aquacomputer/4.jpg
http://213.113.110.198/aquacomputer/5.jpg
http://213.113.110.198/aquacomputer/6.jpg
just ask me more if you need better pictures or if there is some more info that you need.
edit:
i dont know the version, cant find it anyware
Katzenfreund
jeudi 5 janvier 2006, 20:38
Can you please post a screenshot of the aquadrive side, where it is listed and named?
Isaksson
jeudi 5 janvier 2006, 20:40
You mean a better picture of the backside of the controller?
like this picture
sorry i guess you mean somewhere from aquasuite?
x-stars
jeudi 5 janvier 2006, 20:49
As you can see on the picture, your aquastream-controller is a revision 1.0, did you buy the right cable? I'm not quite sure, but I think, the version 1.0 isn't aquaero-capable, yet, you need a new controller or sent your controller to AC to get an update (6,00 Euro + all shipping costs) :-/.
Isaksson
jeudi 5 janvier 2006, 20:56
Thanks for the help,
but if i cant connect it to aquaero why is there a aquaero-bridge, and in the manual to my aquastream:
In the case the aquaero and the aquastream are connected via a 10-pin flat cable...all data of the pump can be supervised and monitored on the aquaero.
so thats not true?
x-stars
jeudi 5 janvier 2006, 21:08
so thats not true?
The aquaero wasn't available, when the AS was released. Since Aquaero Version 1 they startet two more tries with whole new Hard- and Software(Firmware)-Layouts - so when the first aquaero (Rev. 3.07) was released, the aquastream-Controller-Firmware wasn't up-to-date anymore :-/.
Isaksson
I have the wrong cable i have this one
aquastream Verbindungskabel (ab Rev. 1.5) 70cm
thats no good,
does anyone knows whats the diffrense between that cable and the one for Rev. 1.0?
Isaksson
jeudi 5 janvier 2006, 21:10
so it wont work for me even if i get the right cable, the one for Rev 1.0?
x-stars
jeudi 5 janvier 2006, 21:18
It might be, that version 1.0 will work with the aquaero (with the right cable of course) - that's the problem: I can't remember it precisly (there was anything with version 1.0 :'().
The diference with two cables was that one pin isn't connected, you can use one of the cables with every controller, but don't ask me which one - lets wait for someone who can remember better than me :-[.
Isaksson
jeudi 5 janvier 2006, 21:24
aha okey.
so rev 1 only use 9 connection and the other revs uses all 10 connections.
well if i rebuild this cable 10 times then i quess it could work, but thats the hard way.
or maybe something already is broken when i first tryed with the cable for rev 1.5.
jeudi 5 janvier 2006, 21:27
AFAIK the controller must have at least firmware version 1.04 if you want to use it with your Aquaero.
Isaksson
jeudi 5 janvier 2006, 21:32
and how does i find out my firmware version?
what do you think is the best for me to do?
buy a new controller?
jeudi 5 janvier 2006, 22:09
I don't know the shipping costs to germany (for updating) and back to your town but I think a new controller would be the best choice.
Isaksson
jeudi 5 janvier 2006, 22:49
Okey.
I guess you have right.
is there a controller to buy or do i have to send my and make a update?
MUFFDIVER
vendredi 6 janvier 2006, 00:52
nope you just buy the new 1 and stick the old 1 on EBAY ;D
Isaksson
vendredi 6 janvier 2006, 01:02
Thats true, do you wanna buy it ;D
this is what iam planning to buy
aquastream Controller Platine 3.5 (ohne Pumpe)
If i later wanna use 2 pumps in my system how do i connect two pumps to the aquaero?
MUFFDIVER
vendredi 6 janvier 2006, 01:07
And no to your question. 8)
And to be honest i dont know was going to post that myself later this year. But seems as you have asked... SHOGGY???
x-stars
vendredi 6 janvier 2006, 01:18
I am not Shoggy, but here's the answer ;D:
There is a cable with 3 instead of two connectors, so you can connect two Controllers. You need at least one controller of revision 3 or 3.5 to change the adress of this controller (via jumper) :D.
