• 22.11.2026, 12:08
edboswell
fan name aquaero
jeudi 29 décembre 2005, 04:03
hi how can you change the fan names with aquasuite for the aquaero. Also you have not allowed enough spaces to change the flow sensors name to "flow sensor" you can only put "flow senso" :/
MUFFDIVER
Re: fan name aquaero
jeudi 29 décembre 2005, 08:44
would changeing your screen resolution help? or is it fixed?
I have no idea if that help but was justa thought. :-/
x-stars
jeudi 29 décembre 2005, 13:54
The namespace is limited to 10 characters, so write "flowsensor" without space or think about another name :D.
edboswell
jeudi 29 décembre 2005, 18:14
ok iv worked out how to rename the fans :)
MUFFDIVER
jeudi 29 décembre 2005, 18:18
you gunna tell us! ???
PS. Thats like saying i know something you dont.
edboswell
jeudi 29 décembre 2005, 18:30
I thought you named the fan by (within the aquasuite) on the "fans" tab you simply click on fan selection and rename... but this never worked... instead you go on the "fans" tab then look half way to the "fan name" you can then rename it..
the only problem i find with the aquasuite is that you always have to click another tab then go back to the tab you were orginally on before it would update - e.g you are looking at fan 1's status you then select fan 2 in the fan selection but nothing happens - you have to go into one of the other tabs - eg overview - then revert back to the "fans" tab before you can see fan 2's status.
vendredi 6 janvier 2006, 21:41
Edit Names
go to the Fan Tab:
1. Select the old fan name in the edit box --> Fan name:
2. edit the name
3. press return to take over the name
: you can´t edit in the drop down menu, only the text boxes
Sebastian
MUFFDIVER
lundi 9 janvier 2006, 00:11
just saved that nice lil bit of info for when mine turns up 8)
