• 20.11.2026, 06:45
rdrradon
What fittings fit the Cuplex XT?
mardi 10 janvier 2006, 04:25
I ordered my Cuplex XT from Sharka, and got the wrong fittings with it. I meant to buy 3/8" ID 1/2" OD fittings for it. I searched high, and low at the local hardware store, and nothing seemed to fit the threads right. So could I use Koolance, or DangerDen 3/8" fittings?
melon
Re: What fittings fit the Cuplex XT?
mardi 10 janvier 2006, 08:23
You need G 1/8''.
...The connection threads in the bluish colored plexiglass are manufactured in G 1/8"...
(Ps: man kan über treiben)
Top_Nurse
mardi 10 janvier 2006, 15:42
You can get 3/8" ID x G 1/8 hose barbs from Aqua Computer and Sharka should have them as well.
