• 19.11.2026, 16:25
Hysteria2k
aquaero
mardi 10 janvier 2006, 18:27
Hi there :)
Im soon going to buy me a Aquaero, but I have som questions regarding the Aquaro and the controlling unit that comes with the Aquastream pump.
I think I can remember reading somewhere that there's a transistor somewhere on the controlling unit for the pump that is nessacary for the Aquaero.
Before christmas I managed to remove a transistor or something from the controlling unit by an accident.
My question is, is the transistor located where the red circle is marked on the picture I have added under?
And if so, do I have to buy me a new controlling unit?
"Sorry about my bad english"
Re: aquaero
mardi 10 janvier 2006, 18:30
Hi and welcome to the forum :)
You should write an email to support@aqua-computer.de because I'm pretty sure that nobody here can answer your question. And the persons who can (support) do not surf within the forum that much ;)
Hysteria2k
Re: aquaero
mardi 10 janvier 2006, 18:38
Thanks for a REALLY quick answer 8)
Email sent.
Re: aquaero
mardi 10 janvier 2006, 18:56
This are the pads for a capacitor. The value is 10µF/16V.
You dont need a new Controller. Runs the Pump?
Sebastian
Hysteria2k
Re: aquaero
mardi 10 janvier 2006, 19:04
Citation de "Sebastian"
Sebastian
Uhm, 10µF/16V. I have no idea what you meant there :P
But the pump runs yes.
Max_Payne
Re: aquaero
mardi 10 janvier 2006, 20:23
Re: aquaero
mardi 10 janvier 2006, 20:37
The capacitor is there to protect the electronic of the pump and the PSU of your PC. Depending on your PSU the pump maybe works without this part - but you will lose stability.
You can buy a capacitor from us or somewhere else and solder it again. Ask here for the polarity of the part.
