• 19.11.2026, 08:20
verf
Advice, aquagratix for X1800 XT
dimanche 15 janvier 2006, 03:48
So I purchased an x1800Xt and want to set up a cooling solution using "aquagratix for X1800 XT", I'm completely new to this (I honestly don't know anything) so can someone give me the full run down of what extra components I need and maybe some links to figure this out, thanks.
I know usually people that mod and OC know what they are doing, but I believe with some good advice I can get the job done. :D
MUFFDIVER
Re: Advice, aquagratix for X1800 XT
dimanche 15 janvier 2006, 04:36
so you want every item basicaly and the links???
EDIT...
What case you got and what is your system setup ie. CPU etc.
verf
dimanche 15 janvier 2006, 07:27
Citation de "MUFFDIVER"
EDIT...
Yes it seems I need every item and the links, I'm only looking to cool my graphics card because the stock fan cooler is way too loud.
but my CPU is AMD Athlon 64 3800 s939, mobo is Gigabyte GA-K8NF-9 [nforce4 4X/AMD-S939/DDR400/PCI Ex16/SATA/G-LAN]. If you needed that.
I don't know about the case, it's pretty standard, has two fan mounts at the back, one for the power supply and just an extra fan, and a vent on the side for the cpu, and just a few smaller vents here and there. I'm guessing I'll need a new case too?
MUFFDIVER
dimanche 15 janvier 2006, 08:58
Hmmm this is mine so from here look at the top and bottom especially
But can you take a pic of your case from the top (Where radiator and resevoir can go "!but res can go in front!") and from the fan mounts you suggested and from there wel see YA. ::)
But if you do decide to get a new case then just think $$$ going up....
verf
dimanche 15 janvier 2006, 15:23
I'm pretty sure I need the radiator to be external to the case, The reservoir would need to be mounted at the front.
So I need one "aquastream pump", one "aquagratix for X1800 XT", one " airplex evo 360" and one "aquatube".
I'm not clear on the size of hose I need, but I would mount the pump on the side of the case opposite the motherboard. Am I missing anything here?
I can take a picture when I get access to my case next, I suppose it would be difficult for you to advise how the tubing would fit without seeing my case first.
MUFFDIVER
dimanche 15 janvier 2006, 19:59
360 Radiator :o i think that is over kill for the GFX card. You will prob only need the 120 ::) or maybe the 240...
verf
lundi 16 janvier 2006, 10:46
You're right, I'll get the smaller radiator ;D
I see you have alot of connectors on your hose to make tight bends, do you just plug the hose right in or do you need something else to seal it?
MUFFDIVER
lundi 16 janvier 2006, 17:34
nope it is just plug and play and i will get you the list as soon as i can + i need a pic of you pc and where you want it to be mounted so i know what you need ie. connecters and if you are unable to get a pic then just say..
verf
mardi 17 janvier 2006, 12:26
I can get a pic, but like I said I have no access to my PC at the moment to take it. I will post it soon.
MUFFDIVER
mardi 17 janvier 2006, 12:27
alles klar :-X
verf
mardi 17 janvier 2006, 18:07
alles klar :-X
What fittings do I use with "Water reservoir aquainlet Plexiglas without connector"?
verf
mardi 17 janvier 2006, 18:08
verf
mardi 17 janvier 2006, 18:09
fabelmann
mardi 17 janvier 2006, 18:12
1/8" is the connectors size
verf
mardi 17 janvier 2006, 18:21
Citation de "fabelmann"
"Set 2 Stück Anschluss G 1/8, plug&cool straight"
"Anschluss plug&cool straight G 1/8 Innengewinde"
"Anschluss plug&cool straight G 1/8"
"barb 10 mm G 1/8 with O-gasket-gasket"
Which one? And do I need two of these?
MUFFDIVER
mardi 17 janvier 2006, 23:22
Citation de "verf"
this shud do it.
verf
mercredi 18 janvier 2006, 08:19
This is what I want to do: The radiator, pump and reservoir are mounted at the top of the PC case on the outside
So how many fittings and connectors do I need to buy? Any advice on this setup?
MUFFDIVER
mercredi 18 janvier 2006, 13:50
Citation de "verf"
The mount for the radiator to go on the top will send the flow into the case as they are straight connecters so you will be better off having the pump inside the case...
Umm and the resevoir also mounted at the top like this
Is this what you want...
This would make your setup much easier.
If this is a yes then i will sort you an order out.
What case do you have i wll google it and work it out from there. ::)
verf
mercredi 18 janvier 2006, 14:05
;D
No No, The pump, radiator and reservoir are sitting completely outside the PC case on the very top. Not like your computer where it's half out and half in.
I know that's unusual but I like unusual, and my case won't fit the pump and radiator on the inside.
I can get pic very soon, sorry for the wait.
MUFFDIVER
mercredi 18 janvier 2006, 20:40
Yeah no problem.
