• 29.11.2026, 00:50
Jessica
Help with the Aquaero ?
vendredi 3 février 2006, 17:03
Hi to all
Looking for some help on the Aquaero.
I have flashed the firmware and folllowed the instructions and re-set the Aquaero and now i have jumbled up writing on the screen but the Aquaero functions are working.
I have tried putting the firmware back or updating to another version to solve the problem however if i try and upgrade in aquasuite it tells me their is no operating suite in the aquaero.
Also it only detects the Aquareo with the aquasuite software.
Also some of the writing in the aquasuite software is also jumbled up.
Anyone have any suggestions
Best regards
Jessica
x-stars
Re: Help with the Aquaero ?
vendredi 3 février 2006, 17:11
Had the same problem (happened after months of error-less working without any changes at the system/aquaero ::)). Try this:
Start the aquasuite
Change the settings in whtat you like to have
go to the tab "Profiles" and safe the settings
loaf the new profile into the aquaero and make the settings permament by clicking "safe to eprom" in the meün
This did work on my auquaero (and never happened again till now :D)
Jessica
vendredi 3 février 2006, 17:34
thanks for help x-stars unfortunatley has not worked but thanks anyway.
jess
x-stars
vendredi 3 février 2006, 17:40
Which os-version and which firmware-version is installed?
Jessica
vendredi 3 février 2006, 17:45
i think this is the problem
the firmware i have flashed to and says on vdf screen is 4.07.
its saying their is no os on their. This is what i think is the problem.
x-stars
vendredi 3 février 2006, 17:53
There must be an os, without there is no firmware 4.xx (but maybe it's a malfunction).
Download the aquasuite-version from the dl-area and install it. Try to flash firmware 4.09, when this fails try to reflash the operating-system (same like the firmware, in the firmware-folder is a file named 'aquaero os update 202-203.afd4').
Infiltraitor
samedi 4 février 2006, 08:56
The problem is most likely the name of your fans, temp sensors, possibly flowmeter and the aquaero itself following the flash - this happened to me and I thought I'd killed my aquaero too  ;D
Rename your fans and sensors in the appropriate boxes - e.g. 'fan name', and your aquaero on the 'display and hardware' tab in the 'aquaero name' box.
It's prolly best to check the overview page first so you can rename them all in the right order.
Good luck ;)
