• 22.11.2026, 22:56
mcr
airplex evo 240 grille mole
mercredi 14 juin 2006, 15:07
hello
is there anyway to get a mole for the airplex evo 240 radiator grille? its just a sketch of it so i can know where i need to cut the lines etc, a friend of mine spoke of it and he told me i could download it somewhere anyone knows where i can download it?
you know my steez...
J_Tuvix
Re: airplex evo 240 grille mole
mercredi 14 juin 2006, 17:30
mcr
samedi 17 juin 2006, 00:22
cool, but how can i use this, i cant print it out so how can i know what the dimensions are, or is the best way for me to wait till the grill arives then draw it over or something?
J_Tuvix
samedi 17 juin 2006, 02:54
yes you should be able to print it. but if you bought the radiator grille vom ac there is a sketch on the packaging. you can copy that, put it on your case and cut exactly where it is needed.
mcr
samedi 17 juin 2006, 12:52
cool thanks, also i have the hydor pump is there anyway i can get a 8/10 mm hose on it?
