• 23.11.2026, 00:33
ZombieBobie
Temp Sensor in Aquatube
lundi 3 juillet 2006, 21:24
Heya and welcome to me to these forums ;)
Was just wondering what was the best way to install the AC tempsensor so that it keeps an eye on the watertemp inside the Aquatube?
It looks like this:
http://www.aqua-computer-systeme.de/shop…21b0ba8bc28f251
I haven't had a go at installing it yet - cause its still in the mail. However, I can't seem to think of a good way to fit it so that it checks the temp inside the tank.
Any help would be appreciated.
PS: If I'm breaking any forum rules with this post, lemme know, I don't know german so have to "decode" it by wordrecognition from Norwegian and that doesn't always work out too well :P
-ZB
melon
Re: Temp Sensor in Aquatube
lundi 3 juillet 2006, 21:32
Hi...and ah, u know! ;D
You need a G1/8" Plug&Cool Connector ->
Klick
Where you can put in the Tempsensor.
(Ps: man kan über treiben)
Infiltraitor
lundi 3 juillet 2006, 21:35
That sensor is designed to be installed into an 8mm pushfit fitting.
Screw a spare G1/8" 8mm straight pushfit (plug & cool) fitting into a spare port on your Aquatube, and push the sensor in - job done ;)
[edit] Doh! Too slow ;D [/edit]
ZombieBobie
lundi 3 juillet 2006, 21:40
Ahh!
That explains it - thanks a lot :)
If this pops up as me quoting the last post, Im not, I just couldn't find the "reply" button. Hehe.  ;D
Edit: -- I found the edit button though! ::)
ZombieBobie
lundi 3 juillet 2006, 21:54
aha - found it. :o
I'll be fluent in german in no time ;)
