• 30.11.2026, 06:38
Re: Eheim 1048+AC Inlet+AC fluid
mercredi 9 août 2006, 21:28
Maybe it has something to do with the tubing. Maybe it reacts with the ac fluid ???
JaR
mercredi 9 août 2006, 22:23
Citation de "Wolf2000me"
I'm using standard PVC tubes. 6/8cm.
Usually that souldn't be the problem... weird.
badger badger badger ...
Wolf2000me
jeudi 10 août 2006, 01:13
I bought two bottles and I have tried both. Both perform identically. From the moment it hits the distilled water in motion it starts to produce foam.
I took a picture of a bottle with distilled water in which I added the AC fluid. I shook the bottle twice but rather roughly and this is the result:
I also took a pic of one of my AC-fluid bottles.
The s/n as it is readable on the pic is 4260073410151
Since you've all been bearing with me you might as well give me some advice at what to do next :D
I'm thinking about purchasing another additive that is supposed to protect copper from corrosion.
Thanks for the help this far ;)
JaR
jeudi 10 août 2006, 06:31
Copper??? Well you don't really need to protect that.
Wolf2000me
jeudi 10 août 2006, 16:26
Citation de "JaR"
You do when there are other components in the loop which are made of a different metal.
