• 13.10.2026, 13:13
richard.docksey
AMD Athlon 64 X2 Dual Core temps
mardi 22 août 2006, 14:33
Hi.
I've recently tried my hand at watercooling; I'm cooling the following: 4600+ amd64 x2, nvidia 7950gx2 & a western digital raptor hd.
I'm using the gx2 block, cuplext xt block & hd cooler from here, together with the aquatube, aquastream - and a thermaltake bigwater radiator.
I've noticed that my temps (as reported in windows via hardware monitor or everest) for the cpu haven't changed much from air cooling (around 52C) - though the gpu temps are about 10C down (to around 40C).
as noted elsewhere on this forum, these temps don't fluctuate much under load.
I wondered if these are typical temps? to be honest I was expecting to see a lower cpu temp...
R.
JaR
Re: AMD Athlon 64 X2 Dual Core temps
mardi 22 août 2006, 18:19
Thats a single radiator, isn't it?
For CPU and 2x GPU??
badger badger badger ...
richard.docksey
mardi 22 août 2006, 18:33
hi - thanks for the reply.
yep a single 120mm radiator for cpu + 2xgpu + hd cooling block.
are you suggesting that my radiator is way too small?
if so at least there's an easy fix...
R.
Nitrix
mardi 22 août 2006, 21:19
Hi Richard,
Its Pas from aqua-pcs ;)
The basic problem is the rad being to small, in combination with using a hard drive block. Ive got the dual hard drive block in my system and I my temps rased a fair but after installing it. But you are right a bigger rad would solve the problem :)
A_L
jeudi 24 août 2006, 19:12
Richard,
1) You did not tell us the room temp.
2) single "thermaltake bigwater radiator" should be the reason.
suggest to change radiator.
For example of mine gear:
AMD FX60 OC 3.0G => Cuplex XT
ASUS A8N32-SLI => Twinplex XT X 2pcs / local made PWMIC water cooler X 2pcs
ATi X1900XTX => Aquagrati X1900
Pump => Laing DDC-1 18W
Aquatube
120 X 360 Radiator
Hose with 3/8"
3 X 120 fans at 800RPM
temp measured by using compu-nurse
Room temp at 29~30 degrees celcius
idle temp (water) at 33~34 degrees
Full load (water) temp at 37 degrees
SNIFFER
vendredi 25 août 2006, 23:29
A_L,
what flow rate are you getting there out of interest.
Also you mention temp software using compu-nurse. No idea what that is, could you explain that more to me,
Thanks
SNIFFY.
A_L
samedi 26 août 2006, 06:42
Citation de "SNIFFER"
A_L,
Thanks
SNIFFY.
Sorry SNIFFER, I don't know the exact flowrate of my DDC-1 pump,
Compu-Nurse = not the reading from software; but using Electro Temp Censor device for reading.
like this : ( or Aquaero will do the same thing )
;D
richard.docksey
lundi 4 septembre 2006, 17:28
just in case it's of interest to anybody who was following this thread...
the temp I reported at the beginning was probably wrong - there seems to be some nuances in measuring amd64 x2 core temps, and the utils I used at the time (hmonitor/everest) either weren't up to it or I wasn't up to configuring them :)
I now use "core temp" which (from what I can tell) does the job well.
unfortunately, I changed my setup (essentially what I had before + an additional 360 rad) so can't report what this utility would say about the temps before this change... but, for what it's worth, my temps are now reported at (approx) 28-31C idling and 32-38C under various loads. though I can pretty much control this to stick around 31/32C switching all my fans on max.
and the room temp is around 23/24C.
I haven't scientifically measured these temps, it's just what I notice now as I keep an eye on them a lot now.
I hope to measure the water temp soon, but can't decided if I should by an aquaero or not.
Richard.
A_L
lundi 4 septembre 2006, 20:05
Citation de "richard.docksey"
Richard.
Got an AQUAERO!! Richard,
Beleive me. you won't regret for one. :)
Altough I', still getting solution how to connect Multiswitch to Aquaero ;D
Nitrix
lundi 4 septembre 2006, 20:58
Aqueros are great ;D
