• 22.11.2026, 21:57
SNIFFER
Graphics Card bending with watercooling block on
jeudi 9 novembre 2006, 11:54
My XFX 7900 GTX graphics card has one of your 7800-7900 water blocks on it. With the screws tightened up so the components that need cooling touch it, the card always ends up bending. Enough in fact to slightly impede the next PCI slot.
My XFX 7900 GT card in the other watercooled PC does have the same block on it and does not seem to bend as much and works fine. Although the SLI connector is covered by the block, but I don't intend to use that. The SLI is not covered in the other cards case.
My main concern is that the bending card may not work as perhaps the runners inside have snapped/ could snap, under the stresses it's under or changes in heat when its running.
The card has not been used yet as the PC is nearly completed. This week I will find out if the GPU and MB have survived my tinkering with adding the blocks to them.
Does anyone have a similar issue, with their GPU's and has is caused any damage in the past.
SNIFFY
Nitrix
Re: Graphics Card bending with watercooling block
jeudi 9 novembre 2006, 12:20
I have noticed the same thing my dual watercooled 7800GTX's have a fair bit of bend on them but tbh its not really that much of an issue as the card are more Hardwearing then people think and they will be able to take the strain.
SNIFFER
jeudi 9 novembre 2006, 12:36
Cheers Nitrix, thanks for the reassuring comment. Can't wait too see if its going to work. Still alot to do though.
Stefan_K.
jeudi 9 novembre 2006, 15:47
normally it should not bend of course and i think it´s nort mounted right. Don´t want to offend, but i never had acard bending in any direction. Of course i already did a lot of cards for customers.
have a pic ?
Stefan
SNIFFER
jeudi 9 novembre 2006, 17:08
Sure I understand that, are the screws to tight should the ones around the chip be very tight to compress that red disc? Mine are not that tight but doing up the plastic ones makes the card bend alot more.
I cannot position the block any other way due to the holes so how may I have not mounted it correctly.
Any advice
Stefan_K.
jeudi 9 novembre 2006, 19:24
just attach the plastic ones down to the card. do not tighten them too much. if needed leave the heatpads on the rams to have the contact
SolidSnakeHead
samedi 11 novembre 2006, 18:50
I just bought 7800 waterblock, can't find installation manual. Where I can download it?
samedi 11 novembre 2006, 19:10
Welcome to the forum :)
You can download the manual from here.
And please change you signature. It should not exceed 500x80 / 12kb.
SNIFFER
lundi 13 novembre 2006, 00:11
Is it ok to use your blue heat sink pad sold for the ramblock as a thermal conductive over the voltage regulators on the Grahics card. Should I put these over the other bits bar the chip where I will use the artic silver stuff.
I ask cos they seem to produce an oilly residue which I was worried may damage the card?
I think it even shows it on you installation manual, can you put my mind at rest over the use of them.
SolidSnakeHead
lundi 13 novembre 2006, 12:40
The file you shown is like the one that attached with the card. But my problem is I don't know which screw to use and how to attach them. In the package. You gave me 3 type of screw,
1. Short Metal
2. Long Metal
3. Shot and Fat Plastic
Now, I use the 4 of Short metal for screwing around the GPU
The long one for Votage Regulator and the Shot and Fat plastic to attach RAM heat sink on the back side of the card to your block. But my problem is, plastic is the heat transfer material, so that mean my GPU Ram on the back was disconnected with the water block. How should I do?
