• 22.11.2026, 23:47
Halk
Tubing colours
dimanche 10 juin 2007, 16:10
There's 2 UV active types of tubing available from AC.
There's clear, UV blue.
And clear, UV.
I'd like to know what colour the clear, UV turns when UV light is on it.
Also, do you sell any clear non-UV tubing? I'll be using UV dye in my water so there isn't a need for it.
Parts are 61011 and 61003.
Katzenfreund
Re: Tubing colours
dimanche 10 juin 2007, 16:47
there are colored tubings, that aren't UV-activ.
And: the clear, UV has only a very slight effect.
If you do add a colored reagent to your water - such as GlowMotion - it won't be visible.
If you do use destilated water and ACFluid so that you do have the natural clear of the water, you will, however, notice a slight blue effect of the tubing. (But its nothing compared to the blue UV-tubing.)
Re: Tubing colours
dimanche 10 juin 2007, 16:55
Get the "active blue" tube if you want to have a blue color.
It has a nice shiny blue at day and night.
And the best thing: it lasts very long while the blue UV additives lose their luminosity by and by.
AC does not sell any clear plug & cool tubing which is not UV reactive.
Halk
Re: Tubing colours
dimanche 10 juin 2007, 17:53
Right. I don't want UV blue though.
I'm wondering what colour the other type is.
From memory, when I first watercooled my PC I think I ordered "normal" tubing and it was UV blue as well.
Edit : Missed the second post.
Alright, seems this isn't the tubing I'm looking for and I'll need to find some clear tubing from somewhere.
Thanks!
Halk
Re: Tubing colours
dimanche 10 juin 2007, 18:49
Citation de "Katzenfreund"
If you're absolutely sure about that then that'll be fine.
I can get clear tubing in the UK. However, it costs around 3 times what the AC stuff is, and I'd rather use the AC stuff.
I don't suppose you know of any pictures of the green glowmotion using AC tubing?
Re: Tubing colours
dimanche 10 juin 2007, 19:24
;D
Halk
Re: Tubing colours
dimanche 10 juin 2007, 19:28
Sold :)
Thanks Shoggy!
Re: Tubing colours
lundi 11 juin 2007, 15:21
Comparsion between the active blue and the normal tubing:
Halk
Re: Tubing colours
mardi 12 juin 2007, 00:34
Aha. It's more sort of lit up, than blue. Sort of.
Difficult to describe. That picture should go on the shop site though, I can't be the only person confused.
Anyway, I've just placed my order, I very much appreciate the help you've given me Shoggy. I know you don't work for AquaComputer directly (you're involved somewhere though), but you do a good job for em!
