• 12.10.2026, 20:38
Malik
Poweradjust and Laing Ultra
samedi 19 mai 2007, 16:40
I have noob question ;D
Could someone help me how connect this pump ( Laing Ultra ) to this panel ?
CPU: Intel QX 9650
Mobo: Asus Rampage Formula
Mem: Apogee GT 4GB
Sound: Asus Xonar D2
GPU: EVGA GTX 280 FTW
Power: Antec Signature 850W
My LC Project
Katzenfreund
Re: Poweradjust and Laing Ultra
samedi 19 mai 2007, 18:04
Well as the manuel says you can connect the pump to the connector between the tow connectors you are already using.
(So between USB and Power)
Max_Payne
samedi 19 mai 2007, 18:07
In the packet of the poweradjust should be an adapter ...
Greeting Max Payne
Malik
samedi 19 mai 2007, 18:23
Ok Thanks :)
So this look like that:
Something more ?
CPU: Intel QX 9650
Mem: Apogee GT 4GB
My LC Project
Max_Payne
samedi 19 mai 2007, 18:28
No, it's absolutely right ;)
Gruß Max Payne
Malik
samedi 19 mai 2007, 22:59
Ok it's works :)
But i have two more questions ;)
1. Jumper - how to set it up ?
2. I connect panel with USB cable to the mobo ... and nothing. Windows XP shows nothing :( Why
CPU: Intel QX 9650
Mem: Apogee GT 4GB
My LC Project
Malik
dimanche 20 mai 2007, 02:30
Ok, panel works with aquasuite ;D
But it doesn't work with pump. When i change output power from standard ( 100% ) to for example 66%,80% - pump make some strange noise, then stops after that panel start with startboost status. With jumper or without - the same happend.
One think more: Aquasuite shows 45xx rpm ( on 100% power ), but speedfan - 37xx rpm ?? Why ?
Some screens:
CPU: Intel QX 9650
Mem: Apogee GT 4GB
My LC Project
Napalm
jeudi 14 juin 2007, 13:29
the strage rpm readings from speedfan are probably just a mistake by speedfan which can not handle the signal from the panel right.so i would not worry about those readings.since i have an old 230v eheim 1046 i cant help you adjustign the pump with the software.but you should be able to adjust the pump "manually" by wiring it for example with 7v or 5v directly to your psu.but i would try this option only as a last resort option.
