• 29.11.2026, 11:46
Top_Nurse
XT issues
samedi 2 juin 2007, 18:09
Will there be any flow restriction issues if I utilize a Cuplex XT DI and a XT chipset block with a standard Aquastream setup?
gr3if
Re: XT issues
dimanche 3 juin 2007, 13:30
The flow should be okay. As long as it is over 20l/h its should be allright.
Top_Nurse
Re: XT issues
lundi 4 juin 2007, 09:15
The reason I brought this up is that IIRC when the TwinPlex Pro's came out their was some mention about not running them in the same loop with an XT due to flow restriction or pressure drop.
gr3if
Re: XT issues
mercredi 6 juin 2007, 22:11
Which pump? and rest of the Setup?
Napalm
Re: XT issues
jeudi 14 juin 2007, 02:38
in the german forum we had a 60 pages long diskussion about flow restriction with the result that an eheim 1046 (wich is pretty much identical with the aquastream in matters of performance) is pretty much sufficient for any kind of cooling setup.the topic was opened before the xt series coolers were avidable but the setups used for the benchmarks were much more complex.some of them included cpu, chipset,graphicsaccellerator, hard disks, power supply and even hard disks.so due to the complexity of those setups you should be more than fine.if for any reasons the aquastrem would not suffise it would in my opinion result (at least if you test your setup with stadard clock speeds) in bad temperatures which shouldn´t be dangerous for your hardware.
so in the worst case scenario you could always sell the aquastrem on ebay or something but you would not damage your hardware and still bea able to replace it with a stronger pump.
edit:
but just to be sure you should tell us your exact cooling setup.
Top_Nurse
Re: XT issues
samedi 16 juin 2007, 10:35
MB: ASUS A8N-SLI Deluxe
CPU: AMD 3500+ Socket 939
GPU: ASUS EN6600 GT
Memory: Corsair XMS Pro 512 x2 = 1 Gb
CPU: Cuplex XT G 1/8 silver
North Bridge: Twinplex Silver
GPU = TwinPlex Copper
MB VR = #26005 VR cooler
Aquastream pump running at 72 Hz @ 164 liters/hour
Relevant details as below:
http://i12.photobucket.com/albums/a225/T…de/FF_CPU_1.jpg
http://i12.photobucket.com/albums/a225/T…de/FF_GPU_2.jpg
What I would like to do is to put a TwinPlex XT on my NB and can these also be used as GPU coolers? How much of a flow hit will I take using like three of these TwinPlex XT's?
Napalm
Re: XT issues
dimanche 17 juin 2007, 17:23
using the twinplex xts as gpu coolers should be possible.according to ac they have the same mounting system as the regular twinplex coolers but its pretty strange that one can not order them with a gpu mounting kit.i think its just because a normal twinplex is pretty much sufficient for every graphics card.depending on how long you want to keep your 6600gt you should buy a cooler for it or save your money for a cooling sollution for your next graphics card because it would probably also need coolers for the vram.
if you want a twinplex xt anyway for optical reason you should ask the ac support if you could order a twinplex xt with a suitable mounting kit.
even if the waterflow is reduced significantly the aquastream should suffise.
