• 03.10.2026, 19:30
moonrad
Asus Striker Extreme
vendredi 6 juillet 2007, 19:36
Hi guys
I'm currently in the process of researching items for a new build and I'm considering watercooling.
After finding the motherboard I like the spec of, I wondered what cooling options there were. I first of all considered air-cooled, but some of the heatsinks are incredibly large and the motherboard I chose, the Asus Striker Extreme, seems a little cramped to install them on (one heatsink review I read said that when installing it on the Striker Extreme, they had to 'bend' some of the fins to accomodate it). So my attentions turned to watercooling.
Unfortunately I am a beginner when it comes to watercooling, as I have been a sceptic of mixing water and computers(!), but as I read more, I'm finding it increasingly the better option, namely performance, but also asthetics.
So after looking for water cooling solutions, I came across the following forum:
http://www.forumdeluxx.de/forum/showthre…=305813&page=92
Which showed (I think) two different setups for the Striker Extreme, and after squinting at some of the images, I made out the AQUACOMPUTER logo on one of the waterblocks, and here I am.
My question is, does anybody know what components are used in TurricanM3's post to replace the heatsinks surrounding the CPU? And also what waterblocks are used for the CPU/Chipset/RAM?
I'll probly use 2 x BFG 8800GTX cards with the in-built waterblocks for the Graphics, so GPU waterblocks won't be neccessary.
Any help greatly appreciated.
Nitrix
Re: Asus Striker Extreme
vendredi 6 juillet 2007, 19:59
Hi there,
Cpu = Aqua-computer EVO (Discontinued)
Ram = Aqua-Computer Ramplex
Chipset = Aqua-Computer Twinplex XT
VRM's = Asus mosfet cooler (26005)
moonrad
samedi 7 juillet 2007, 04:47
Citation de "Nitrix"
Hi there,
Thanks for the info.
Do you have any suggestions for an external radiator?
gr3if
lundi 9 juillet 2007, 12:26
Aquaduct?
