• 23.11.2026, 00:31
cypriobrit
Correct mount for Cuplex Di
samedi 11 août 2007, 03:11
I see there is a thread in the german watercooling forum about the correct way to mount your cuplex on a dual core CPU - could someone please translate the final outcome of what way to mount it?
Google translator didnt help much!
Thanks
gr3if
Re: Correct mount for Cuplex Di
samedi 11 août 2007, 03:52
Look at my sgnature ;D
When can see a silver thing inside the Di there is the inlet and when u can face cooper there is the outlet.
cypriobrit
samedi 11 août 2007, 19:51
Thanks - but i meant the way you mount it in the motherboard.
Should the inlet/outlet be above each other or side by side? There was some discussion about the positioning of the cores under the heat spreader of the CPU i think.
Hope that is clearer.
gr3if
dimanche 12 août 2007, 15:55
Which Cpu do you have? It depends on your die.
cypriobrit
dimanche 12 août 2007, 16:16
a 6400 core duo.
