• 17.11.2026, 23:10
xesperto
Aquaero Controling Aquastream
lundi 13 août 2007, 13:22
Hi all!
I have bought an Aquaero 4.0 and i have an aquastream( with a pump ) , and i want to control it via Aquaero !
i allready bought the "aquastream connection cable (> Rev. 1.5)" and i have connected between both components, but when i turn on the computer the PUMP does not Start !!
what ím doing wrong !?
thks
X
Infiltraitor
Re: Aquaero Controling Aquastream
lundi 13 août 2007, 21:26
Are you supplying power to both the Aquaero and Aquastream controller from your PSU?
If so, don't!
You only need to power the Aquaero if you have the Aquastream controller connected to it.
xesperto
mardi 14 août 2007, 00:21
thks for the reply !!!
you were right ! i had both conected to the PSU, and now i remove the aquastream from it, but the problem remains !:(
i beleave that my aquastream is this version aquastream 12V-pump, Firmware 1.04.
it´s a old aquastream !!! is there, any incompatibility with the newst aquaero ( 4.0 ) and this aquastream !?
thks
mardi 14 août 2007, 02:17
It is recommend to use a controller with firmware 1.05 or later.
r1ppch3n
mardi 14 août 2007, 03:00
Citation de "xesperto"
[quote author=xesperto link=board=7;num=1186996966;start=0#2 date=08/13/07 um 22:21:04]Firmware 1.04.[/quote]
there's your problem
pumps prior to the aquastream 1.5 had a slightly different connection cable which you will find in the shop ;)
xesperto
mardi 14 août 2007, 12:46
thks all for the reply
So the solution is to buy a new Aquastream !! right !? i don´t have any other solution !?
b0nez
mardi 14 août 2007, 13:36
Yes, there's an other solution.
Buy a new controller and it should work.
:rolleyes:
melon
mardi 14 août 2007, 19:05
You just have to buy the right connection cable for your Pump. You now have a < Rev. 1.5 Pump connected with an > Rev. 1.5 connection cable, the correct cable you should buy is the < Rev. 1.5 Version.
Just ignore me! ;D
(Ps: man kan über treiben)
