• 28.09.2026, 22:55
MDHellDK
pump noise
vendredi 17 août 2007, 13:56
Hi all
i've finished putting my system together and have filled water in it, but i can't stop my pump from making noise...
For how long should the pump make noise, i've tried both deariation and normal mode... the pump is really noisy in deariation mode
i'm using a high end 360 system with aquastream pump.
gr3if
Re: pump noise
vendredi 17 août 2007, 15:24
The pump shoud be quiet after a while. Normally there is a bit air in the pump which should be gone some in some time.
MDHellDK
Re: pump noise
vendredi 17 août 2007, 15:30
thx, but i have had the pump running for hours and it still is were noisy
Morten
gr3if
Re: pump noise
vendredi 17 août 2007, 15:50
Shake it Baby ^^
u can shake it and maybe try got turn round in the deariation mode.
My pump makes 5 secs after starting horribble noise and then it goes silent.
u can also try to change the frequency of the aquastream sometimes it helps to give her 74heart
MDHellDK
Re: pump noise
vendredi 17 août 2007, 16:13
thx again  ;)
i have turned it upside down, i have shook all night long  ;) and still noisy, now i have upped the frequency on the pump to 70hz, the noise disappears after 5 secs but there is no flow?? and theres white foam/bubbles in the hoses
Morten
gr3if
Re: pump noise
vendredi 17 août 2007, 16:43
Whoup?^^ There should be flow...
U are sure that the pump gets water?
MDHellDK
Re: pump noise
vendredi 17 août 2007, 16:58
hi again
i have upped the frequency to 63Hz, then i used a straw, placed it on the aquajet and helped sucking out the air ;)
now theres no noise and the water runs like a river :o
i just hope that i can recreate it after refilling the system with clean water ???
thx a lot for your respons ;)
Morten
gr3if
Re: pump noise
vendredi 17 août 2007, 17:07
Np. Sometimes it helps to suck water out of the upper access
