• 18.11.2026, 15:31
xesperto
Tubemeter with Aquaero
dimanche 26 août 2007, 13:19
Hi all !!
i have a aquaero 4.0 and a tubemeter !!
when i´m going to see in the aquasuite i have 2 main TABS, the first is the aquastream TAB and the second is the tubemeter Tab, but in the firts( Aquaero) i don´t see the tubemeter settings !!!
what is wrong !?
thks :D
Infiltraitor
Re: Tubemeter with Aquaero
dimanche 26 août 2007, 17:17
I'm still using all the tabs in my Aquasuite - the tubemeter doesn't appear on my Aquastream tab either; it's on the Overview tab.
xesperto
dimanche 26 août 2007, 17:29
Yes its in the overview page !!! but it´s does not work !!!! it´s simply dead :(
but in the other hand in the tubemeter tab it seens to work just fine !!!!
i have connected it directly to a USB connection is it right !? or i need to connect to the Aquaero directly !? if so !? how !?
thsk
Infiltraitor
dimanche 26 août 2007, 18:07
Ah, right - I see.
What version Aquasuite are you running?
xesperto
dimanche 26 août 2007, 22:28
i´m running 4.43 !!!
Infiltraitor
dimanche 26 août 2007, 23:42
So on your Aquaero display (LCD or VFD), the water level is displayed okay? Assuming you're not running the Lite version.
Have you tried uninstalling Aquasuite and reinstalling it?
Top_Nurse
lundi 27 août 2007, 02:10
Aquasuite => aquaero => Return to default settings.
Does this help out?
xesperto
lundi 27 août 2007, 11:58
it does not display nothing in the aquaero !! ( LCD)
just a question !! the Tubemeter it supose to be connected to a USB Port right !?
gr3if
lundi 27 août 2007, 13:02
yep
xesperto
lundi 27 août 2007, 13:05
thks !! just Checking !! ;D
Infiltraitor
lundi 27 août 2007, 18:52
My Tubemeter is connected to the header pins in my Aquaero.
xesperto
mardi 28 août 2007, 12:01
header pins ? where !? sorrry i´m rookie on this !! :D
melon
mardi 28 août 2007, 12:40
You can choose between the USB connection or the header pins of the Aquabus:
btw
If you want to connect the Tubemeter to the Aquabus, you have to buy the optional connection Cable: 93266
(Ps: man kan über treiben)
