• 11.10.2026, 18:49
Re: Announcement: aquastream XT
vendredi 19 octobre 2007, 15:54
Citation de "divve"
I just read the following in the German forum section:
"AquabusKommunikation bevorzugt bearbeiten" aktiviere ist es also nur möglich bis 74Hz zu gehen, mehr gibt das AE ja nicht her,"
Does this mean that the AE display will also never show more than 74hz, or is it possible to simultaneously obtain the frequency signal from Aquabus and control the pump through USB? Thanks.
you can also control the pump via usb and aquabus simultaneously, the aquaero display the correct frequency. With the aquaero you can set only 74Hz (max), with usb 100Hz (max).
vendredi 19 octobre 2007, 17:15
If you would like to connect more than one device to the aquabus you simply need an Y-Cable. It's an bus system and you can add up to 128 devices to the aquabus. The aquabus is a serial 3-wire bus based on the I2C-bus. Any type of device has a special address. So the master can speak with any of the devices by addressing it.
