• 17.11.2026, 03:55
virtualrain
Aquaero firmware not remembering relay settings!
jeudi 18 octobre 2007, 00:06
Hi, both my Aquaero's will not retain the relay settings after a power cycle.
I have tried to set them both to "Power Switch" but everytime the power is cycled on the PC, they come up set to "ATX-Break Line" which renders my PC's power switch unusable. I have been forced to disconnect my power switch from the motherboard and use the powerswitch on the motherboard instead... otherwise I can't even power my computer on.
Thanks for any help with sorting this out.
gr3if
Re: Aquaero firmware not remembering relay setting
jeudi 18 octobre 2007, 01:53
You know that you have to save the settings in the eeprom?
virtualrain
jeudi 18 octobre 2007, 05:15
Yes... good suggestion, but I'm using the "Save data to EEPROM" in the "Extras" menu after adjustments. It seems to remember everything else I set, except for the relay parameters.
gr3if
jeudi 18 octobre 2007, 20:11
Hm weird.
Latest Firmware? Latest Aquasuite?
virtualrain
jeudi 18 octobre 2007, 22:31
Yes to both. It also happens on both of my Aquaero's so it's not an isolated problem.
gr3if
jeudi 18 octobre 2007, 22:34
Can you check if this is not a cable related issue? Maybe with another cable? And check the pins twice plz.
x-stars
vendredi 19 octobre 2007, 01:38
Long time (about 2 years) ago, but in that times you had to flash the firmware after changing the relais-setting because the aquaero needs to know the settings before booting and thus before there is eeprom-access. So, set it once again to your favourite setting and then reflash the firmware. Don't forget the eeprom-reset afterwards.
virtualrain
lundi 29 octobre 2007, 19:17
Citation de "x-stars"
This worked. Thanks!
