• 07.10.2026, 20:28
TheRave
Two questions (Tubemeter and jalcds)
samedi 12 janvier 2008, 22:08
I've just received my Aquaero, AquaTube, Aquastream and various other bits and pieces. They are all very cool.
I have two questions though:
- The AquaTube I have is the version with G1/4 holes. Is there a Tubemeter for these size holes or an adapter of some kind?
- Is jalcds still supported, I went to their site (www.jalcds.de) and it says "Forbidden"?
Thank you.
Stefan_K.
Re: Two questions (Tubemeter and jalcds)
samedi 19 janvier 2008, 21:07
there is no tubemeter for G 1/4
and yes jacld is supported
El_PResidente
Füchschen Alt-Meister
mercredi 23 janvier 2008, 16:53
Yes, Jalcds seems to be dead since months now. Any, at the end there was no "life" on the Website since 01/2006. I think there was no further development for Jalcds for the last 2 Years.
If you need a tool to write on the aquaero-display, try LCDHype instead. www.lcdhype.de
I use it and they even got a aquaero-plugin, that reads all data from the aquaero without running the aquasuite.
Thats maybe no so important for you, because the display is on the aquaero ;) , but i just want to point you to a more actual "living" lcd-control-software.
For me lcdhype has more posibilities than jalcds.
An there are more actual plugins for lcdhype. (nvidia-temp, speedfan, tban, aquaero, winamp, everest, cpu-info ......)
Give it a try. Maybe it works with the controller-interface for hd47780 or crystalfonts-serial.
Good luck.
El_PResidente
If
