• 07.10.2026, 10:38
BetterRed
How important is EMF shielding for the Aquastream?
mardi 5 février 2008, 15:51
The AC FMJ-case is mentioned in the pump section:
Since the motors of the radial pumps emit a magnetic field, we recommend the application of our FMJ-casing. The casing protects the harddrive disks and data lines from the irradiation of electromagnetic fields.
A search of the AC site does not give much more for 'FMJ' - and they are not available at the danish reseller afaik. Anyway, if the case is not safety grounded, how much shielding will the FMJ actually provide?
pharao
Re: How important is EMF shielding for the Aquastr
mardi 5 février 2008, 17:22
the FMJ is discontuniued, since there was no provable incidents, when the magntetic field ever disturbed a HDD.
using the FMJ in comination with a pump that has a fixed blade wheel (e.g. all Aquastream pumps) might even prevent the pump fron starting alltogether. if you use a eheim 1046 or 1048 with a loose blade wheel you can use a FMJ.
- and btw the magnetic field has nothing to do with the grounding of your case
