• 22.11.2026, 11:37
wedontdoduvets
Black Multiswitch ?
mardi 12 février 2008, 13:44
I'm looking to setup some lights for my ac computer .
Where is the best place to buy a Multiswitch , also does this come in a black version ?
Cheers ;D
Mike44
Re: Black Multiswitch ?
mardi 19 février 2008, 22:41
Citation de "wedontdoduvets"
Hmm, not too sure about the best place to buy it, but yes, there are black faceplates that you can buy with it: http://www.aqua-computer-systeme.de/shop…ilder/53038.jpg
It's just the individual face plate that you buy. You don't get to choose between the silver or black when you purchase the multiswitch. Silver comes with it already, then buy the black one extra.
Mike
pharao
mercredi 20 février 2008, 05:39
Citation de "Mike44"
http://www.aqua-computer-systeme.de/shop…038.jpg[/quote]
that's an aquaero, not a multiswitch. afaik there are no black face plates for the multiswitch.
Mike44
mercredi 20 février 2008, 07:23
OMG, holy crap, I'm so dumb - I was doing something else while getting the picture.  I guess I can't multitask!  Okay yea, sorry.  Duh!!
Well, I thought that I saw it somewhere before.  If I come across it again, I'll let you know.  It may just have been some guy's mod where he painted the silver cover plate himself or something.
In the meantime, it doesn't look like anything from AC directly for a black multiswitch cover plate: http://www.wizdforums.co.uk/showpost.php?p=5730&postcount=8.
Sorry!
Mike
wedontdoduvets
jeudi 21 février 2008, 08:44
Damn i really wanted a black version , looks like i might have togo for the multiswitch LT and hide it in my case. I wonder why they didnt release a blackface plate :(
drbo
jeudi 21 février 2008, 14:41
there is no black frontplate for multiswich.
But you can drill holes in a frontplate for aquadrive, (2mm and 3,5 mm holes if I remeber correctly) as I did http://www.diskusjon.no/index.php?act=at…=post&id=211472
The only problem with this solution is that the 4 pre drilled fixing holes dos not fit, so after drilling new holes, the old ones might show a little ...
But AC; why dont you make a batch of black ones, that should be easy done? 8)
WS: W10 | Asus Rog Strix X299 | i7-7820X | Asus Rog Strix 1080Ti | Dominator 32GB | Corsair 860AXi | 512GB Samsung EVO 970 |WC: EK-Waterblocks | AC- Monitor and Control | 3x EK-CoolStream PE 480 | LD PC-V8
Gamer:W10 | Asus R4E | i7 3930K | 3x Asus HD 7970 CF | Dominator 16GB| Corsair 1200AXi | 2x120GB I520 Raid0 | WC: EK-Waterblocks | AC- Monitor and Control | 4x Airplex PRO 360 | MM Extended Ascension
wedontdoduvets
jeudi 21 février 2008, 21:54
Citation de "drbo"
Well that mod looks ok , might give it ago :)
