• 30.09.2026, 19:37
etoel
HDD case blocking Aquastream XT headers
mercredi 12 mars 2008, 12:55
I have my pump mounted in the aquabay using the supplied rubber feet. When the front of the aquabay is aligned with the case my 5 1/4 rack is blocking access to the power and connectors.
Is this supposed to be this way? Or have I mounted it wrong?
Thanks
Top_Nurse
Re: HDD case blocking Aquastream XT headers
vendredi 14 mars 2008, 05:24
Dremel time? ;D
b0nez
vendredi 14 mars 2008, 07:49
Afaik AC has bring out an new Rev last year. The AS XT will fit in the new one.
:rolleyes:
etoel
vendredi 14 mars 2008, 09:47
Citation de "b0nez"
A new rev of the Aquabay? I have the 1.5 and I can't find anything newer.
I'm fine with some dremel magic - I just wanted to know if there is an easier way - seems odd that it shouldn't fit out of the box in a LianLi case...
Maybe using the plate that is used for mounting the pump on a radiator and another set of those rubber feet - it will lift it another cm out I guess.
b0nez
vendredi 14 mars 2008, 13:58
ACHTUNG: Wenn Sie die Pumpe in einem aquabay verbauen möchten, so benötigen Sie einen aktuellen Anschlussatz und ein aktuelles aquabay. Alte Versionen vor September 2007 sind nicht kompatibel.
The newer Aquabays, build after August 2007 wont have this Problem.
But you solved it your way ;)
:rolleyes:
etoel
samedi 15 mars 2008, 00:27
Citation de "b0nez"
I purchased the bay only a few weeks back so I'm a bit surprised thay would give me the old version, but as long as it's solvable 8)
b0nez
samedi 15 mars 2008, 00:34
Where did you buy the Aquabay?
:rolleyes:
etoel
lundi 17 mars 2008, 03:31
Citation de "b0nez"
Directly from AC...
mardi 18 mars 2008, 11:14
You need the newest aquabay (please make a foto to show your version). Also you must use the newest adapters and it's only useable with bent plug&cool fittings.
It's definitly possible to install the pump like older versions if you have any parts as described. We sold the new version of the aquabay a few month earlier then we stated to sell the aquastream XT so if you bought it from us there should be no problem.
etoel
mardi 18 mars 2008, 14:19
Citation de "Stephan"
I ordered mine mid February:
Code source
1
2
5. 34902 aquabay AT (Einbaurahmen für aquatube) Rev. 1.5
aquabay AT (installation bay for aquatube) Rev. 1.5
I had an e-mail exchange with AC prior to ordering regarding the two versions of the bay (AT and Baydream) and concluded that only the faceplate differed - the Baydream having the connectors under instead of at an angle) so I ordered the AT (it looks nicer IMO).
It looks like this:
The picture is from an early test so the pump is mounted too far to the right.
I don't know anything about newest adapters either - I used what you supplied...
What do you mean by "only useable with bent Plug&Cool fittings" - would any bent fitting do or is the plug&cool version smaller?
