• 15.11.2026, 05:25
Big_Daddy
Looking for help with USB power Adjust
jeudi 8 mai 2008, 21:57
How do I hook up a 2nd DDC on the power adjust? The manual doesn't say anything about it.
Thanks for your help.
Re: Looking for help with USB power Adjust
jeudi 8 mai 2008, 22:07
Welcome to the forum :)
It is not possible to add a second pump. The poweradjust was designed to use it with one Laing pump. A second pump would destroy the controller because of an overload.
Big_Daddy
jeudi 8 mai 2008, 22:26
Even though it states:
Moreover, the poweradjust USB also has an alternative power output which can be used for other pumps or very efficient fans with rpm-signal.
jeudi 8 mai 2008, 22:32
Yes, it can be used for other pumps - but not at the same time ;)
You could use more than one pump if they have a small load. The Laing pumps have a huge load; especially the starting current of them.
Big_Daddy
jeudi 8 mai 2008, 23:02
So then, this won't work for me. As I need to control 2 pumps, and i don't want to purchase a second one.
