• 10.10.2026, 20:36
Omnilord
Aquaduct 360 XT flow sensor problem
jeudi 31 juillet 2008, 20:48
Hello,
It shows that the coolant (water flow) is 0,0 l/h. The only time it shows a value other than 0,0 l/h is a couple of seconds after a pump firmware flash. It will then return to showing 0,0 l/h. I know the water if flowing, but I do not know at what rate.
I am running aquasuite 4.61.00 and have flashed the aquaduct using the firmware file aquaduct360mkii_firmware110.afd4 and the pump using the firmware file aquaduct360mkii_pumpfirmware_1017.afd4.
My CPU,a QX9770, is not adequately cooled and has an idle temperature around 60 C at 2,4 GHz (clocked down from normal at 3,2 GHz).
Anyone have any tips?
Regards,
Sveinung
MUFFDIVER
Re: Aquaduct 360 XT flow sensor problem
jeudi 31 juillet 2008, 22:46
Hi and welcome to the AC forums ;D
Refrense the flow showing 0lh i cant help you there but about your CPU temps being high i may be able to help.
What is in your loop ie.
Res > Pump > CPU > NB > SB > Res
Also what GFX card(s) are you using?
maN1C
vendredi 1 août 2008, 14:51
Are you abselutely positivly sure water is flowing?
I'd say CPU temps indicate that the 0 flow is correct reading from flow sensor.
Muffdiver, video tutorials from aquacomputer clearly states that what order waterblocks are in the loop is completely irrelevant for cooling performance. I disagree with this, but this is what ac claims.
Omnilord
vendredi 1 août 2008, 16:08
Thanx Muffdiver :)
I was under the impression that loop order was less significant, although it will probably have some degrees of difference.
My Loop is this:
Res > Pump > NB > SB > GPU 2 > GPU 1 > MOSFETs > CPU > Res
GPU 1 is 2 degrees warmer than GPU 2.
GFX cards are two XFX factory overclocked 8800 GTX
maN1C: I am sure the water is flowing yes. When I added color it spread throughout the system. Water is also flowing over the aquaduct bridge and it is def. cooling the system. GPU 1 under stress test tops out at around 64 degrees (idle now is 53 degrees).
The aquaduct also has temperature readings of the water inbound and outbound.
MUFFDIVER
samedi 2 août 2008, 04:58
Citation de "maN1C"
Meh!
If you read previous posts by me you will see that i disagree with what you say :)
AC do not lie.... do they ;D
