• 01.10.2026, 12:57
markcu
Water Cooling SkullTrail?
vendredi 15 août 2008, 16:50
I'm currently in the process of watercooling my Skulltrail rig.
To cool the two e5420's (overclocked) I'm using a pair of XT DI coolers.
To cool the GPU's (2 x Gtx280's) I'm going to use Aqua-computer G280 coolers.
But the issues start with the north and south bridges.
Idealy I'd like to cool the north bridge with another XT Di as is approx the same size as a CPU. but it looks like I need an XT DI with an X38 mount....does such a thing exist?
Also the I'm using a Blastflow southbridge cooler that cools the southbridge and two Nvidia chips, although it seems to do the trick it always seems to collect air and there is no easy way to get it out. Are there any plans for AC to produce such product?
MUFFDIVER
Re: Water Cooling SkullTrail?
vendredi 15 août 2008, 19:06
Citation de "markcu"
Do a cut down and drill you own holes :)
Also fir the air, Do you mean you get air in your Flow?
If so turn on and rotate PC ;D
gr3if
samedi 16 août 2008, 18:39
There is a Twinplex Xt di available with mountig Kit for x38, maxbe that helps you.
