Vous n’êtes pas connecté.
BlueAqua
BlueAqua
Citation de "Nemesis"
what i think?
nice
now build ist and always keep in mind: this forum loves pictures ;D
BlueAqua
Citation de "lion33319"
First off, welcome!
Well, i think its a great idea getting the AC stuff to the states and showing off what german engineering is capable of
Do you already have an idea where you are gonna place all the AC components (pump, radiator etc.) in this case?
The reason i'm asking is that i got the same case (well, the pc-v1000..the smaller one) and im not sure where i should place the pump and expansion chamber yet.
I thought about placing them in the lower chambers (where the Hardrive rack is), but tubing these suckers to the rest of the components on the MoBo would be a pain since there's only one small hole which leads from the lower compartments to the main MoBo compartment. Any ideas??
Keep spreading the word dude!
lion33319
BlueAqua
Citation de "BlueAqua"
Since you have this similar case, do you think you could put an Airplex Evo 360 in the top width wise? I know your case is has a little less depth than the V2000. I've looked at the dimensions and I think it'll fit. How far from the edge of the case does the top of the PCI slots come? I only have 45mm to work with on each side and I'd like it exactly centered.
I bought an AquaBay to put the AquaTube and I think I'll put the pump there too since it has a mount for it, but we'll see.
I was going to leave the bottom pretty much open for expansion. I think I might put a Vapochill down there eventually.
And I'll take my Dremel to the case if I have to to make holes for any tubing I need.
I just wonder if this one pump will be able to handle 3 harddrive blocks, 360 radiator, Aquatube, CPU, AquagrATIx, and a chipset cooler. Maybe I should run two loops. Any suggestions?
BlueAqua
BlueAqua
@ blueAqua
i just tried it out with a piece of paper which i cut down to size to see if there's gonna be a problem with the radiator.
There wont be a problem with the length of the radiator. The only problem i see is that your gonna block 3 of your pci slots.
I got an audigy card myself which sits in the second pci slot ( AGP port -> 1 free pci slot -> audigy card)... so thats about all you'll be able to fit in there when u install the radiator.
The other problem could be the jumper connectors (power switch etc.) since the board ist upside down now, the jumper connectors are on top and might smack into the radiator (in my case). I also got a SATA connector right next to the jumpers which could cause some problems as well... hope you can follow me
of course you could place the radiator a little off the center ( to the right when looking at the front of the case) when placing it in the top of the case...but that would look pretty §$%& up.
BlueAqua
I measured about 45mm from the mobo tray to the end of a jumper connector. So that would mean that thats 7mm too long... tuff luck.
quote]
Did you measure to the end of the serial connector itself of just the connector on the motherboard itself. I've seen serial ATA connectors that are at a right angle that just might work for this. It'll be a tight squeeze if possible at all. I think since the evo 360 is only 403 mm long and the case is 590mm deep then maybe the serial ATA connectors on the ASUS board might be ok.
lion33319 you have helped a lot, I really appreciate you taking the time and measuring your case and looking for possible solutions for me. Thank You.
Anyways, this is a quick photoshop picture of how I want to align the stuff in the drive bays, any suggestions?
Thanks once again.
BlueAqua
BlueAqua
Citation de "Slazer"
ahh i got something in ym mind you can put the controller of the Aquastream pump on the back of the Aquaero control modul ! btw. nice project and yes 21 feet should be really enough !!
regards slazer
BlueAqua
i measured the end of the serial connector. Its gonna be a tight squeeze, youre right... but with a little pullin and shoving it might work.
edit:
your case setup: looks good but consider that the radiator is gonna reach into the second drive slot (from the top).. in other words, the radiator is gonna reach 1cm or so into the second slot...your gonna get problems with your aquabay there. As you can see, its not all that easy. The only real bitch is the radiator. But once u got him installed right, you should be fine.
Now that's stuff I need to hear. I didn't know that the pump controller could mount to the back of the Aquaero. That'll leave me with another drive bay open. Hmmmm, what should I do?
