• 26.11.2026, 12:19
New: aquastream upgrade kit to aquastream XT USB
mardi 11 décembre 2007, 19:19
With the aquastream upgrade kit all aquastream pumps can be converted to the aquastream XT USB. Only a few simple steps are necessary, these are are described in the illustrated instructions.
The upgrade kit is available as ultra-, advanced- as well as standard version and corresponds to the functional range of the respective aquastream XT pump.
The ultra variant has the largest scope of delivery and permits to assemble the controller on the rear side of the pump. The necessary fixing material as well as a an adapted cover are contained in the extent of supply.
Furthermore the ultra variant is delivered in addition with a temperature sensor which can be attached to the internal connection of the controller. This sensor replaces the temperature sensor which usually measures the water temperature and is pre-assembled in the aquastream XT pump, but not available at the additional upgrade, however.
The standard and advanced variant are mounted in the PC case with the mounting holes of the circuit board. A later installation to the rear side of the pump is possible furthermore, too.
The upgrade kit can be ordered as of now in our web shop. The upgrade Kit ultra costs 55.99 euros, the version advanced 39,98 euro and the standard variant is available for 29,99 euro.
Here is a picture of the upgrade kit ultra:
pharao
Re: New: aquastream upgrade kit to aquastream XT U
dimanche 19 octobre 2008, 16:42
this isn't a new Product (look at the Topic's date) - I just had to delete a spammer's post...
just in case andybody is wondering why this topic is on top again...
