• 10.10.2026, 23:52
jesuscry
a 1060 ehneim
samedi 9 mars 2002, 17:17
is it good for use a waterblock
is there a lot of noise?
who has a 1060?
Dragonclaw
Re: a 1060 ehneim
samedi 9 mars 2002, 17:27
Its a little bit to powerfull ;)
of course you can use it, but a 1046 or 1048 would be better. They are small enough to be put into the case and their power is enough to serve several coolers and radiators. And they make hardly any noise, while you can hear an 1250 or a 1060 quiet good.
These pumps are only necessary if you want to use a Bong instead of a Radiator because then you need higher pressure.
Also most people here in the Forum use a 1046/48, and only a few a 1250, i don't know anybody who has a 1060.
Cu
Dc
jesuscry
Re: a 1060 ehneim
dimanche 10 mars 2002, 02:13
::) ::)you say
you say its a big noise
Manuel_aka_MDK
Re: a 1060 ehneim
dimanche 10 mars 2002, 10:36
Hi!
@ jesuscry
I don´t have a watercooled system yet, but i´ve read in this forum long enough ;D . So I can tell you that the Eheim1046 is quite good, very silent (just like the other models) and sufficient in most of the selled systems. The 1048 has double the power (600 l/h) of a 1046 and is only necessary if you use many components like CPU-cooler plus 2 GPU-cooler, one or two radiator, many tube-connections or something like that.
But you can make your decision on your own ;) .
CU
If you find some spelling mistakes you can keep them ;)
@Dragonclaw
Gutes Englisch ;D !
Dragonclaw
Re: a 1060 ehneim
dimanche 10 mars 2002, 10:55
I think the 1060 is not absolutly quiet because users of the 1250 say that they can here theirs and the 1060 is much more powerfull than the 1250
http://www.eheim.de/f/technik_pumpen.htm
Here is some information about the eheim pumps, fortunatelly in French, which may help you ;)
Cu
Dc
@Manuel_aka_MDK
8) ;)
Manuel_aka_MDK
Re: a 1060 ehneim
dimanche 10 mars 2002, 12:58
Aaaaaaach sooooooo....
Jetzt kapier ich! Jesuscry kommt aus Frankreich!
Na ja, brauch immer ´n bischen länger, trag halt ne Brille ;D
Manuel_aka_MDK
Re: a 1060 ehneim
dimanche 10 mars 2002, 14:36
@ DragonClaw
Du hast ne KurzMassage ääh Message ;D
jesuscry
Re: a 1060 ehneim
dimanche 10 mars 2002, 15:43
thank i read
then i understand the 1060 isn 't noisly
Manuel_aka_MDK
Re: a 1060 ehneim
dimanche 10 mars 2002, 19:22
All the models of Eheim are very silent. But I think the 1060 is really too powerful for the watercooling-systems sold out in Germany. Like DragonClaw already said.
I don´t know what you can get in France or what you want to buy or which system you are working on.
jesuscry
Re: a 1060 ehneim
lundi 11 mars 2002, 05:46
i explain my futur work
a system waterblock OUT
my 1060 will be 2 or 3 meter of my computer
ok?
or in another room
and after a complete chipset graphic card power
understand ?
in france i can have a 1060 for 85 euro
elfstone
Re: a 1060 ehneim
lundi 11 mars 2002, 19:21
Well, i have the Eheim 1048, and i use 8m of water-cable, a CPU and a Graphikcardcooler, and don't have any problems.
I guess, 1048 would be enough for you, if not 1250 definitly is.
Passiver Autoradiator mit Plug&Cool zu verkaufen.. Bei Interesse PM
jesuscry
Re: a 1060 ehneim
lundi 11 mars 2002, 19:55
yes but i want more and more powerfull
i will buy the aquamedic 2500 38w up 2m60
good?
Assassin
Re: a 1060 ehneim
lundi 11 mars 2002, 22:01
hehe i wont argue with you about pumps, just post pics when you finished your setup ;D
Zitat von »Dino«
...lauter spinner ;)
dino
jesuscry
Re: a 1060 ehneim
lundi 11 mars 2002, 23:38
pics?
Manuel_aka_MDK
Re: a 1060 ehneim
mardi 12 mars 2002, 00:58
That means pictures.
jesuscry
Re: a 1060 ehneim
mardi 12 mars 2002, 04:03
yes i know
where is this picture?
why AFTER WHAT?
max
Re: a 1060 ehneim
mardi 12 mars 2002, 07:39
after finishing your watercooling installation you make some nice little pictures just for us ;D
jesuscry
Re: a 1060 ehneim
mardi 12 mars 2002, 17:27
yes ok
but why?
Dragonclaw
Re: a 1060 ehneim
mardi 12 mars 2002, 18:38
just because we would like to see how your PC with Watercooling is looking ;)
nearly everybody has a different case, or other ideas how to build up his system and most of them, if they have the possibilities, present their solutions here in the Forum.
For some who are new in this buisnes it might help when they have problems how to install theirs, and pictures say much more than words ;)
Cu
Dc
jesuscry
Re: a 1060 ehneim
mardi 12 mars 2002, 22:24
OK i made now my watercase with plexi
ans i receive my pomp the end week
when i finish i do some pictures on my server
it 's ok
