• 26.11.2026, 21:24
Braincolt
Re: Fotostory 2! P4-System und aquatube horizontal
mardi 6 août 2002, 22:45
I'm sorry but I haven't MSN...
I use it for a few day's in the past, but after a system crash I doesn't install it again...
If you like to chat with me in an email, so you can use my adress:
Braincolt@craft464.de
Sorry for my bad english :(
www.ttecx.com The computer online magazin
garacs1
mercredi 7 août 2002, 00:20
Citation de "Braincolt"
Hi Braincolt!
Thanks for your message! I will surely ad your email account to my friends' list! Anyway, we can continue to write to each other here in this forum, ok?
Oh, BTW, as I said in another thread, if my German was as good as your English, I'd be living in Berlin right now!!!:D
WEll guys, lets go on with details about your rigs: tell me what you've got running up ther in Germany! ;)
Oh, much probably I'll open a new thread just not to add useless pages to this one, I'll certainly do it tomorrow, ok?
Waiting for your descriptions!
Byez for now
Garacs1 ;D
I do not want what I haven't got
nordy
mercredi 7 août 2002, 03:14
yes, now I have added you, too.
I think the length of this thread isn't the problem there are much longer ones in this forum.
But probably it would be wrong to write here because it's not the tema of this thread.
hope to meet you sometimes in MSN
cu
nordy
Die Kunst ist nicht mit dem Kopf durch die Wand, sondern mit den Augen die Türe zu finden!! Lieber künstliche Intelligenz als natürliche Dummheit!
Braincolt
mercredi 7 août 2002, 07:25
You can add a Thread to the Off-Topic...
There we can talk as much as we would :)
palu
vendredi 9 août 2002, 15:16
Hallo Leute ,
die Bilder zeigen einen dunklen Ring um die Aquatube ! Was ist das ????
Metall ?
Kann man das Ding irgendwo kaufen ?
palu
FUNKMAN
vendredi 9 août 2002, 15:21
Da wird Dino aus optischen Gründen den Rest von dem aus dem Casedeckel geschnittenen Metall verwendet haben.
Das deutet er in seiner Beschreibung auch an.
Also, wenn du sauber arbeitest, dann hast du nach dem Ausdremeln / -flexen für den Airplex auch genügend Metall übrig, um dir auch sowas zu basteln... :D
Buzzfuzz
vendredi 9 août 2002, 16:24
Also...
...erst einmal möchte ich hier Dino meinen Respekt zollen. Sieht echt super aus. Da ich mich in letzter Zeit mehr mit dem Thema WaKü beschäftige, habe ich viele PC's gesehen. Aber dieser gefällt mir am besten. 8)
Er ist schlicht, edel und nicht so übertrieben. Der einzige Nachteil dieser Variante ist meiner Meinung nach das befüllen. Es ist da eher unhandlich. Ich muss mich jetzt auch entscheiden, welche Variante ich nehmen möchte. Will auch in den Club der WaKü-Boys... ;D
Buzzfuzz
Wenn etwas schiefgehen kann, wird es schiefgehen. So sprach Murphy und so wird es geschehen... *g*
Braincolt
vendredi 9 août 2002, 16:37
mhh ihr kennt doch sicher diesen kleineren ausgleichsbehälter von innovatek..
wenn man jetzt den AT vorne einbaut für die optik, und den von innovatek innen zum befüllen, wäre optik und komfort super gelöst
Mole3800
dimanche 11 août 2002, 03:23
@dino wie hast du das systhem befüllt???
Sir_Flauschi28
lundi 12 août 2002, 04:18
Also ich hab an euch AT-Fans mal ne Frage:
Is der Plug&Cool-Anschluss zum Innovatek anschluss kompatibel?
Ich kann nichts dafür, aber der Wasserkühler von Inno war einfach besser ;).
Nur die At muss jetzt wegen ihres Designes sein, da liefert Inno nämlich echt nur hässliche Produkte.
Also ich wäre allen dankbar, die mir diese Frage beantworten.
MfG Sir_Flauschi28
Braincolt
lundi 12 août 2002, 23:40
also die Sache ist die... Ich steh genau vor dem selben Problem ^^
aber ich habe es gelöst... also, geh hier einfach in den shop und bestell dir den aquatube mit dem anschluss 8mm tüllen.. fertig :) kannste doch auswählen
Sir_Flauschi28
mercredi 14 août 2002, 04:11
hmmm, den gedanken hatte ich auch schon, aber mir sind die tüllen eigentlich zu unsicher und wie sieht den die titan-AT mit tüllen aus? ^^
MfG Flauschi
PS: Aber danke für deine Antwort
Meidscha
jeudi 15 août 2002, 10:57
Hai!
Citation de "Mole3800"
Den Rechner zum Befüllen einfach auf die Rückseite kippen. Wasser rein, Pumpe an usw, usw...
Gruss,
Meidscha
Dino
jeudi 15 août 2002, 14:34
hi
genau so wars ;) hatte ich das vergessen zu schreiben? nein? ;)
dino
Starrr
jeudi 15 août 2002, 23:25
Moin,
Dino, du bist schuld, in spätestens 1 Woche (hoffe ich) werden die restlichen Teile bestellt und dann wird vollständig nachgebaut (wenn die Tele hier jemals ankommen *seufz*)
In diesem Sinne
Starrr :D
arcus
mardi 3 septembre 2002, 16:24
reicht für sone hübsche fontäne auch die 1046? oder hast du gar nicht die 1048?
AMD Athlon XP2100+ auf EPoX 8K5A2+ in CS601blue durch ein Enermax EG465P-VE versorgt und bald durch ein ac-system gekühlt ;)
Greenhorn
mardi 17 septembre 2002, 17:40
yo !! das würde mich auch interessieren ! ::)
ich finde das design total genial ! (spingbrunnen in blau) ;D !!
Greenhorn
Starrr
mercredi 18 septembre 2002, 21:21
Ich habe noch nicht alle Teile (verdammt noch mal, warum fehlt immer was finanzielles *grrrrrrr*) daher hab ich bis jetzt alles ausser den AB (und damit der Springbrunnen). Da ich aber zusätzlich zum Proz die Grafikkarte und Chipsatz kühlen muss (wenn Lüfter raus dann gleich so komplett wie möglich) habe ich mir gleich sicherheitshalber die 1048 geholt.
Aber jetzt iss die letzte Bestellung raus, fehlt nur noch die Lieferung, dann wird weitergebaut *g*
Mfg
Starrr
Wuselrob
mercredi 18 septembre 2002, 21:27
hmm sieht fett aus.. aber zum befüllen müsste man dann immer den pc umdrehen damit nix rausläuft oda ? :D
und ist der AT dicht ? also läuft da bei der plexischeibe nix raus ? hab auch schon allerhand bestellt.. und die idee, das ganze hotizontal zu bauen ist goil :)
Meidscha
jeudi 19 septembre 2002, 11:33
Hai!
Citation de "Wuselrob"
...aber zum befüllen müsste man dann immer den pc umdrehen damit nix rausläuft oda ? :D
und ist der AT dicht ?...
Du stellst den Rechner zum Befüllen einfach auf die Rückseite. So oft passiert das ja auch nicht, zumindest bei mir... ;)
Und ausgelaufen ist bei mir mit dem Tube in der Front bis jetzt auch noch nichts.
Gruss,
Meidscha
