• 29.09.2026, 10:22
Zwendel
Einige fragen
lundi 17 février 2003, 19:08
Hallo, mein deutsch ist nicht so gut also gehe ich meinen fragen im english stellen. Hope you don't mind.
I was thinking about ordering the following setup :
cuplex evo (Vierloch-Halterung Sockel A, Schlauchtüllen 10mm)
airplex evo 120 (Schlauchtuellen 10mm)
aquatube (Blau, Schlauchtuellen 10 mm)
Einbaublende aquatube
Bausatz Beleuchtungsmodul grün fuer aquatube
Eheim 1250
Papst Luefter 4412 F/2GML 3-Pin mit Tachosignal
Luefterentkopplungsgummi 120 mm
(m) PVC-Schlauch 10x1,5
acfluid - Korrosionsschutz
1.Any comments/improvements would be welcome.
2.Also I would like to know what the delivery time would be of such a system. Is it possible to order this from Belgium (As I live in Antwerp)? How much would the transportation cost be?
3.Is it possible to connect the 10x1.5 hose to the Eheim 1250? Or do I need to order different couplings? Like these ones : Schlauchtuellen 10 mm G 1/8 mit Dichtung
Vielen dank
Athlon 2400+ @ 2255MHz (12,5x180MHz) 1,75V AKASA Silver Mountain 2 + 60mm Delta ASUS A7N8X Deluxe 256MB Corsair XMS3000 (2-2-2-5) 30GB Maxtor ATA-133 7200rpm 60GB Seagate Barracuda IV ATA-100 7200rpm
BlueDevil2001
Re: Einige fragen
lundi 17 février 2003, 19:36
Yes! ;D
Why the Eheim 1250 ???
Its much too big...
Why no Plug&Cool?
slame
Re: Einige fragen
lundi 17 février 2003, 19:51
hi ..
take plug´n´cool. easier and safer.
slame
Zwendel
Re: Einige fragen
lundi 17 février 2003, 19:53
Ok,
1. I took the 1250 thinking it would be the best. So you're saying that the 1048 is powerfull enough? But what if I want to add a chipset and graphic cooler later? Will the 1048 still be powerfull enough?
2. I have read that it's better to use large diameter tubes and the plug and play inner diameter is only 6mm. Larger diameter would provide better cooling.
chip
Re: Einige fragen
lundi 17 février 2003, 20:17
1. The 1048 is also more then enough. I have 1x cuplex, 2x twinplex, 2x aquadrive an 2x 120 airplex evo and i use the 1046. The 1046 ist absolutely sufficient.
2. The diameter of the tubes are not important. I had 6mm tubes and changed them with 8mm and i still have the same temps.
504
nix
MojoMC
Re: Einige fragen
lundi 17 février 2003, 20:29
full ack to Chip504.
Take the 1046, its more silent than 1048.
This company (aqua-computer) has tested their products with different hose diameters. 10mm makes no difference to 8mm.
Willkommen in Bruchtal, Mr. Anderson.
Zwendel
Re: Einige fragen
lundi 17 février 2003, 20:46
Since I'm now using a 60mm delta with 46,5dBA :o any pump I use will be less loud ;D
So I think I'll take the 1048 instead of the 1250. Do the 10mm tubes fit on the standard 1048 couplings?
What about the delivery times? How long did it take between ordering and delivery for you guys? I've heard from some people that it may take up to 2 months ???
TrAgIc
couplingsRe: Einige fragen
lundi 17 février 2003, 20:53
For the Eheim you get Plug&Cool couplings from AC.
Delivery time, takes really 4 - 8 Weeks. My delevery takes 6 weeks.
But you can go to a Reseller, like www.Low-noise.de
JE
Re: Einige fragen
mardi 18 février 2003, 05:09
first thing: dont take the 1048! its absolutely noch necessary.. a 1046 will be more than enough.
second thing.. why pvc? plug and cool is much more secure and much easier to handle.
and you could need some "winkel" (90°).. and, of course, a set for "entkopplung" for the eheim would be a good idea.. it is just for a much more silent pump.
P.S. dont drink and write a foreign language.. ;)
