• 07.11.2026, 03:58
poly
Is P&C interchangeble?
dimanche 2 mars 2003, 23:18
Hi! I´ll write in english because i´m Swedish  ;D
Is the Plug&Cool plugs interchangeble between different aquacomuter products? --I could then order a Airplex360 with bent plugs and replace them with the straight ones from the Eheim 1048 P&C-kit?
And: Would the Eheim 1048 fit in 3 5,1/4" bays? Standing in the bottom of the rack...
/ Hugo
SoulReaver
Re: Is P&C interchangeble?
dimanche 2 mars 2003, 23:24
it depends on the size of the plug's screws. as far as i know in your case it wont work, because the plugs on the eheim are just adapters and dont actually have screws. you can check the shop, and then look in ersatzteile, there you can see which plugs fit on which ac product.
mfg, gurke
Citation de "DerFredMan"
nein, dass cs601 hat 2cm dicke stahlbleche, da muss die flex hin!
:o:o:o und für die lan kommt der gabelstapler her.....;D
r1ppch3n
dimanche 2 mars 2003, 23:29
no you can't
the coolers and the aquatube surely do have all the same plugs (so THEY are interchangeable ;)) but the ones of the pumps and the airplex are different and won't fit anywhere else...
edit: do i really type that slow? ::) ;D
poly
dimanche 2 mars 2003, 23:39
Thank you.
Checked up a little bit closer.
>> The P&C plugs from for example a twinplex is interchangeble with plugs from the eheim P&Q-kit. -so you were right.
Been using babelfish alot today :)
