• 23.11.2026, 00:17
poly
Fill/bleed and flush a system
lundi 3 mars 2003, 22:32
Hi!
Does anyone have any tips on how to fill, and flush, a system with a horizontal mounted aquatube?
-Hugo
EpS
Re: Fill/bleed and flush a system
lundi 3 mars 2003, 22:37
nothing easier then this:
Unplug all Cables and lay your Case on his back... ;)
Flying_Dutchman
lundi 3 mars 2003, 23:13
[klugscheiß]The right grammer would look like this: "Unplug all cables and lay your case on its back..."[/klugscheiß]
Sorry, ich weiß nich, was Klugscheiß auf Englisch heißt... :P
moe
lundi 3 mars 2003, 23:27
hi and welcome...
i think, it would be not bad, if you install a T-part (in german t-stück) to plug a piece of tube with an cork to flush out.
for refilling the tip ahead would be the only possibility and is really easy to realize ;)
greetz
EpS
lundi 3 mars 2003, 23:33
Citation de "Flying_Dutchman"
;D
Der war gut...
Aber Recht hast du. Hab auch kurz überlegt und mich dann fürs falsche entschieden... ;)
poly
lundi 3 mars 2003, 23:55
Thanks!
Figured the filling tip out within seconds after posting ;D
Another question:
Will the P&Q plugs work with silicone tubing with the same messurements?
-Hugo
kampfsau
mardi 4 mars 2003, 00:04
no way, jose!
only PUR-tubes... silicone is way to soft! your system would leak like a women during her period! ;D
454-bigblock
mardi 4 mars 2003, 00:05
Citation de "poly"
Thanks!
Another question:
-Hugo
No, you should´t do that. AC advises trongly to use PUR-tubings, because Silicon is too soft to fit corrrect.
Where are you from?
454-bigblock
mardi 4 mars 2003, 00:08
Citation de "KampfSchwein"
no way, jose!
Ui! Du bist ja krass :-)
kampfsau
mardi 4 mars 2003, 00:09
hehehe
krasses KampfSchwein ;D
das "schwein" in dem namen is nicht umsonst gewählt ::)
moe
mardi 4 mars 2003, 00:16
no way, jose!
*lol*
how ugly u are.......
kampfsau
mardi 4 mars 2003, 00:21
Citation de "moe"
*lol*
actually i´m very handsome! ;)
i´m just a sick bastard ;D ;D ;D
poly
mardi 4 mars 2003, 00:22
OK, I´ll probably order the stuff with 10mm hose plugs instead then. Not a big fan of L-plugs..
Citation de "454-bigblock"
Where are you from?
From sweden.
kampfsau
mardi 4 mars 2003, 00:31
Citation de "poly"
L-Plugs?
i think you´re mistaken... the PnC-plugs come in 2 versions: straight and L-type... it depends which suits you better :)
but trust me: the PnC-system is WAY more efficient... it´s a well tested model taken from air-pressure equipment and works absolutely leak-free! (of course if you connect it right ;D )
my first watercooling system had a mix of hose-plugs and PnC-connectors... after the first installation i had already ordered PnC-stuff for the rest of my system, i was astonished of the effectiveness and yet the simplicity of the PnC-system! :D
trust us users on this one... ;)
poly
mardi 4 mars 2003, 11:39
Maybe you´re right.
How much can you bend the P&Q hose? Bending diameter?
woodstock
mardi 4 mars 2003, 11:55
HeyHey!
Look at this! Most of the People have used the P&C System and as you can see, the PUR hose can be bend in a relatively small radius. As far as I know it can be bend a lot better than silicon tubing because it will not fold as easy as silicon!
Woodstock
edit:
ojo's Case
Akula's case
frolicfresser´s case
creep
mardi 4 mars 2003, 12:55
...es heisst aber grammar
