• 20.11.2026, 15:10
Mrdonbonjovi
I'm from the States... A few questions.
dimanche 9 mars 2003, 03:59
Just heard about this company and all I have to say is wow! Great products and from what I head excellent quality. My major question is on the availability of products in the US or able to be shipped to the us. What would be the best vendor either in the US or for shipping to the US. Also the radiator looks like a tank and the resivoir is a beast aswell. I would like to use them both. I have this case: http://www.newegg.com/app/Showimage.asp?…-125-225-02.jpg . I was wondering if they woud fit on the top with the mounting things, with the resivoir in the front-top and radiator in the back-top.
Thanks!
anschobi
Re: I'm from the States... A few questions.
dimanche 9 mars 2003, 04:45
which radiator do you mean?
if you take the biggest one there is no place for the resirvoir on the top!
Mrdonbonjovi
dimanche 9 mars 2003, 05:03
Will there be room for the 2 120mm fan one? or just the 1 fan one?
geCKo
dimanche 9 mars 2003, 10:47
If you'd like the radiator on the outside (the top) of the case there is also enough place to use the AP360 (the radiator with 3 120mm fans) but if you'd like the radiator in the case there is just room for the AP240. I'm sorry my english isn't the best.
Is this your idea of mounting the liquidcooling(the dual radiator is on the top)
best regards
geCKo
NF7-S=XP1700@2300mhz=512mb Twin/WB=V8440
Citation de "Man_In_Blue"
Amn neme ein Blat Papie.
thetruephoenix
dimanche 9 mars 2003, 11:00
you can bring both the radiator and the reservoir on the top of the Case(if the Power supply isnt too big), but you`ll probably lose one or two 5,25"-places(sorry, dont know the word).sometime aquacomputer ships to the usa, handle it with Stefan or the Support, they`ll help you.if you get no answer in 3 days, dont desperate, they some hundreds mails every day...
BLOODFEUD
dimanche 9 mars 2003, 13:06
hi there
i don't think that it the radiator and the resevoir would fit on top of that case because the power supply would be an problem!
but you can put the radiator on the top and the reservoir in the front pannel (like in the case of geCKo)
update
in the pics i saw that there is a little bit of room between the power supply and the top of the case perhaps you have enough room there so that you can put the radiator in there
you have to measure the room in there and compare them to the airplex 240
sorry for my english ::)
banditexl
dimanche 9 mars 2003, 14:11
Dont forget if you want to buy a complet kit, you can´t use the eheim pump ,because we have 230 V power supply system in Germany. I mean in US you have 110 volt.
geCKo
dimanche 9 mars 2003, 14:42
I'm not sure, but the hydor l20 should work in the usa too!
geCKo
JE
dimanche 9 mars 2003, 14:59
the voltage shouldn't be a problem.. you can use an adapter.
banditexl
dimanche 9 mars 2003, 15:17
I think you can buy the set without the pump and buy the pump in the USA, or maybe the ac team can order that pump for you. ;)
www.eheim.com
Mrdonbonjovi
dimanche 9 mars 2003, 16:55
THanks, Does anyone know the measurements of the 2 fan raid when with the internal mounting? I have seen some pics with the internal mount and is seems like it hangs a little bit of metal below where it needs to end... maybe a dremel or something to fix that!
thetruephoenix
dimanche 9 mars 2003, 17:13
the measurement in millimetres of the dubleradiator:
h/w/d: 264(with plugs + 17)x130x50
dunno this in inch...maybe someone else here?
Mrdonbonjovi
dimanche 9 mars 2003, 17:24
hmm, yea it seems like the ps would be a problem. Would it be possible to modify the powersupply casing to have the raid fit? Or does anyone know of a smaller powersupply... Also just wondering about US sales distribution!
geCKo
dimanche 9 mars 2003, 17:27
What type of power suply do you have?!?
geCKo
GMonCh
dimanche 9 mars 2003, 17:42
*G* *G* The Aqua-Power is smaler ::)
thetruephoenix
dimanche 9 mars 2003, 17:45
but much longer ::)
and d***(censored anyway::) ) expensive too
geCKo
dimanche 9 mars 2003, 18:41
@mrdonbonjovi: You've got to much money and not enough room?!? No problem! here's the solution :
just by an aquapower ps it solves both of these problems..*g*
geCKo
Mrdonbonjovi
dimanche 9 mars 2003, 18:54
I wouldn't say that exactly. What are the major differences in the 1 fan and 2 fan rads? I could just get the 1 fan one if the performance isn't majorly effected. I also noticed there was an external mount for the 3 fan rad, is there one for the 2 fan radiator. That would be cool to have that external and the res on top!, very pimp!
thetruephoenix
dimanche 9 mars 2003, 18:58
the external mount fits for the triple and double radiator.the difference between the one-fan radiator and the two-fan radiator is quite big.the small on is just something for people with really few space...its more like a toy in my eyes ;D
Mrdonbonjovi
dimanche 9 mars 2003, 19:14
Is ther a picture of the 2 fan external mount? The site only have the 3 fan one... The 3 fan mount wouldn't leave me with enough room for the res on top, but the external 2 fan would be AMAZING cause it would solve all my problems!
