• 08.11.2026, 11:00
gerald
help with UV light kit
mardi 29 juillet 2003, 00:34
hi I'm in the states, i ordered the UV light kit on accident, and now i have to put it together my self, but i have no idea where everything goes, it comes with a trasistor, does anyone have a guide? or can someone help me?
cosmic7110
Re: help with UV light kit
mardi 29 juillet 2003, 01:25
:o ::) ??? :P :-[
sry habs net so mit english
//edit soviel wie ich jetzt verstanden hab haste das UV light kit und es is kaputt und du weist wasde damit machen sollt oda ?? ;D
TrOuble
mardi 29 juillet 2003, 01:40
Do I understand you right? You dont know how to put the cables together? (sry for my bad english)
hope the picture can help you ...
kaZuo
mardi 29 juillet 2003, 01:44
I think he means the uv kit for the aquatube which he has to solder together.
TrOuble
mardi 29 juillet 2003, 01:47
Citation de "kaZuo"
und wieso hilfste ihm dann net?
Did you mean the uc kit for the aquatube?
(this one : )
gerald
mardi 29 juillet 2003, 02:09
yes i do not know how to wire that.. can someone show me a close up image or tell me where the stuff goes.. thanks!
TrOuble
mardi 29 juillet 2003, 02:53
yes i can ... its not too dificult ...
Sry but i m not able to to tell you how to wire it together (because of my bad english ...)
Martin666
mardi 29 juillet 2003, 03:24
Ok you have the Molex-Plug and the Metalpins. Now "crimp" 2 of these Metalpins on one end of this Cable. On the other End connect the red cable with the resistor and the longer pin from the LED. The connect the LED's shorter Pin with the black Cable. Now put the Metalpins in the MolexPlug. Red cable to Yellow Cable from Power supply. And Black Cable to Ground (Black).
If it doesn't Glow, change the polarity from the LED... (I'm actually not sure about the shorter and longer Pin of the LED)
And dont forget the shrinking "tubes". Use them for Isolation...
TrOuble
mardi 29 juillet 2003, 03:40
thx Wudelschnitz ... hätt ich auch gern erklärt aber mein englisch reicht dafür net aus :'(
Martin666
mardi 29 juillet 2003, 03:56
Glaub mir ich hab mir das auch ausn Fingern gesaugt...
Wenn ich nur wüsste was löten auf english heisst...
Und hoffentlich fragt er nochmal hier, bevor er nen kurzen auslöst....
gerald
mardi 29 juillet 2003, 04:09
thanks alot guys...i will try that!
Tahigwa
mardi 29 juillet 2003, 04:41
Citation de "Wudelschnitz"
"löten" übersetzt man mit "solder" :)
Ich benutze zur schnellen Übersetzung Babylon, einfach auf das zu übersetzenden Wort klicken, dann erscheint die Übersetzung. www.babylon.com
Tahigwa
A64 NC3500+ 939 zu verkau
gerald
mardi 29 juillet 2003, 07:48
Dank für die Hilfe jeder
traurig ist mein Deutsch schlecht :-[
TrOuble
mardi 29 juillet 2003, 16:22
Citation de "gerald"
Unser englisch aber auch ;D
