• 17.06.2026, 16:17
Risky
Aquareo Durchflusssensor
vendredi 5 septembre 2003, 12:50
Appologies for my lack of language :-[
Could someone tell me if this flow-sensor uses 1/4BSP or 1/8BSP Threads? I ask as I am using 8/10mm P&C-type fittings and I was trying to keep all the connectors at 1/4BSP or above.
Many thanks, Risky.
2.5+Gigs of Celery Power! Systems | OCS-D2OL
Sprudeldudel
Re: Aquareo Durchflusssensor
vendredi 5 septembre 2003, 13:56
What is important, is not if G1/4 or G1/8 is used. The inner diameter of the Flow-Control as such is most important. I opened a thread on that, but could not get an answer.
However the answer to your question seems to be G1/4 according to a post from ThaDog in this thread http://forum.aqua-computer.de/index.php?…&threadID=23731
DSEDS
vendredi 5 septembre 2003, 14:42
There are two versions, one with 8/10mm screw fittings. I think this will be the right one fior you.
Kind Regards
Edit:
The aquaero is not released yet, but it will be available "soon".
