• 30.09.2026, 19:10
realsmiley
werbebanner im neuesten icq lite beseitigen
mercredi 30 juillet 2003, 10:40
..falls sich noch jemand über den erneuten einzug der werbeindustrie in icq, diesmal in der lite-version ärgert.. >:(
http://www.bigblueball.com/forums/topic.asp?TOPIC_ID=4118
klappt wunderbar - sogar mit eigenem logo 8)
BongoKarl
Re: werbebanner im neuesten icq lite beseitigen
mercredi 30 juillet 2003, 15:19
Trillian ...
fliegenduennschiss
mercredi 30 juillet 2003, 15:28
meinste des da: http://www.allicq.com/index.php?op=getfile&id=35 ?
wenn ja, geht net ::)
cu, TheCrow
realsmiley
mercredi 30 juillet 2003, 16:23
Citation de "TheCrow"
Ne, ich meinte den Text darunter ;)
To remove the Ad's in 1253 goto your LiteDataFiles directory. Delete the files Banners.xml clbanner.xml and psearch.xml.
Next put a folder for each you deleted. Yes put .xml just as if it was a file. This will prevent ICQ from auto updating the file.
This will replace the WinAmp ad with an ICQ lite logo, and remove banner ad's from you message.
If you would like to make the ICQ lite logo blank. Also delete climage.html and create the folder climage.html in that place. This leaves and ugly white box though so I prefer just leaving the logo :-)
Just a quick note - you can change the climage.gif to be whatever takes your fancy. I changed mine to be my company logo
Thanks Jeremy. I was very sad to see such a big advertisment area. Also thanks joolz to inspire me about the use of that area. Now I change that box to a small slide show just like a photo gallery.
1. Replace the original climage.html by the following HTML:
<HTML>
<HEAD>
<SCRIPT>
// how long an image is shown, any transition time for IE is added
var delay = 6000;
// IE transition duration, specify as floating point in seconds
var transDuration = 2.0;
var transType = 23; // random change as needed
var images = new Array();
preloadImages( // use your images here
'image1.gif',
'image2.jpg',
'image3.jpg'
/* or do a loop for indexed images
for (var i = 0; i < 7; i++)
preloadImages ('img' + (i + 1) + '.gif');
var cnt = 0;
function preloadImages() {
for (var i = 0; i < arguments.length; i++) {
images[images.length] = new Image();
images[images.length - 1].src = arguments;
var imgTag = '';
imgTag += '<IMG NAME="theImage" ';
imgTag += document.all ?
' STYLE="filter: revealTrans(duration='
+ transDuration + ',transition=' + transType + ');" ' :
imgTag += ' SRC="' + images[0].src + '"';
imgTag += '>';
function nextImage () {
cnt = ++cnt % images.length;
var img = document.theImage;
if (img.filters && transType == 23) // get random type
img.filters.revealTrans.transition =
Math.floor(Math.random() * 23);
if (img.filters)
img.filters.revealTrans.apply();
img.src = images[cnt].src;
if (img.filters)
img.filters.revealTrans.play();
setTimeout('nextImage()',
delay + (img.filters ? Math.round(transDuration * 1000) : 0));
</SCRIPT>
</HEAD>
<BODY border="0" topmargin="0" leftmargin="0" scroll="no" ONLOAD="setTimeout('nextImage()', delay)">
<TABLE WIDTH="100%" BORDER="0">
<TR>
<SCRIPT>
document.write(imgTag);
</SCRIPT>
</TR>
</TABLE>
</BODY>
</HTML>
2. save the file and change the attribute to "read-only", "hidden" and "Archieve". It is necessary otherwise the html file will be restored by the original one when you start ICQLite.
I tried jpg file also and it works. remember to cut all images to right side that is 120x90 pixels. Have fun!
:P ;)
BiosTauBaer
jeudi 31 juillet 2003, 02:42
ich hab das normale icq (full) und bei mir sind die banner weg dadurch, das ich icq+ draf geamcht hab!, das is für icq skins, aber die werbebanner ntfernts auch, ob das auch mit icq lite funtz kann ich dir ned sagn...
TrOuble
jeudi 31 juillet 2003, 03:02
cool funkst sogar alles :o endlich keine nervige werbung mehr !! THX
fksystems
jeudi 31 juillet 2003, 20:02
Ich benutz schon lange das trillian statt dem icq.
Das mit dem "authorization erforderlich" und der fehlenden ip-adresse ekelt mich einfach an. :)
realsmiley
vendredi 1 août 2003, 01:11
sorry, eigentlich hatte ich hier nicht vor, einen aber-ich-habe-eh-ein-viel-besseres-und-cooleres-programm-und-bin-der-beste-thread zu eröffnen .. oder hat das was mitm thema zu tun? .. :P :-X ;) :-*
TrOuble
vendredi 1 août 2003, 01:39
tja is immer hier so ... man sagt : so und so kann man das machen und sofort kommen sie aus allen ecken und meckern man soll gefälligst n anderes proggie benutzen ... gewöhn dich dran 8)
fliegenduennschiss
vendredi 1 août 2003, 01:40
aha, kann mir des mal bitte jmd. auf deutsch übersetzen ? :-*
cu, TheCrow
TrOuble
vendredi 1 août 2003, 01:41
cu, TheCrow
IHR SEID ALLES BESSERWISSER
PS: besser? *g*
fliegenduennschiss
samedi 2 août 2003, 15:51
äääähm... nö ::)
cu, TheCrow
FragMaster.nsn
mercredi 6 août 2003, 16:01
So kurz und knapp übersetzt:
Vorgehensweise:
Im Verzeichnis LiteDataFiles löscht ihr nachstehende Dateien:
banners.xml
clbanner.xml
psearch.xml
Danach legt ihr Ordner an mit den Namen der Dateien an, damit die autoupdate Funktion diese Dateien nicht wieder erstellen kann.
Ergebnis:
Banner unter den Messagefenstern gelöscht.
Banner im Top des ICQ Fenster ohne Funktion.
sinnlose Google Suche entfernt.
EddiG
mercredi 6 août 2003, 16:02
wieso nicht gleich miranda ? Schneller, kleiner, umfangreicher, werbefrei, ressourcenschonender etc ... ;)
Wenn das Schifferklavier an Bord ertönt, Ja da sind die Matrosen so still (ja so still) ;)
realsmiley
mercredi 6 août 2003, 16:37
@fragmaster danke für die übersetzung! :)
@nem2k
Citation de "Nem2k"
Citation de "realsmiley"
