• 01.10.2026, 05:54
GI_Biochip
New to watercooling
vendredi 17 août 2007, 13:01
Hello everyone!
I have used bolt on watercooling kits in the past, but they have proved to be rubbish. Now I aim to buy a case from here, but I have a few questios:
Is there a block that can be fitted to an Ageia PhysX card (BFG variant), and, the motherboard is a DFI ICFX3200-T2/G ,
(see here: http://us.dfi.com.tw/Upload/Product_Picture/icfxB.jpg ). So, which blocks can be fitted to that board, which will be running 2 HD2900XT, PhysX card, TV card, 5 hard drives, soundcard, and an intel quad core CPU? Also, OS is Vista 64, does the aquero software work in Vista?
gr3if
Re: New to watercooling
dimanche 19 août 2007, 23:53
For the Motherboard you have to use this:http://www.aqua-computer-systeme.de/shop…6fa7179768527aa
or that:http://www.aqua-computer-systeme.de/shopsystem/product_info.php?cPath=7_10_1823&products_id=104&osCsid=de50637968dd9c75e6fa7179768527aa
i dont know the range of this motherboard hookups
for the bfg card u can may use this:
http://www.aqua-computer-systeme.de/shopsystem/product_info.php?cPath=7_10_1822&products_id=86&osCsid=1198a9c7fd54718a00bcca821424a08f
And about the software sry i dont know
GI_Biochip
lundi 20 août 2007, 10:16
Citation de "gr3if"
Thanks very much! I am a step closer now!
gr3if
lundi 20 août 2007, 11:32
KK np maybe write Shoggy a Pm he knows usually which software runs on what system.
lundi 20 août 2007, 15:04
Citation de "GI_Biochip"
Yes, works with all Vista versions.
