• 02.10.2026, 17:42
Psychor
MPS 400 & AQ5 Pro Settings?
samedi 27 avril 2013, 04:28
I have my MPS 400 connected to my AQ5 Pro (1030) via the Aquabus. The MPS is detected in AS2013 as Flow 11.
What does "Digmesa" means and what do the various values mean? What should the MPS be set to? I have 1/2" ID 3/4" OD fittings connected to the MPS.
Thanks.
Psychor a envoyé l’image suivante :
samedi 27 avril 2013, 07:05
This settings not relevant for the mps.
The mps output also scaled values. This setting has no effect.
Psychor
samedi 27 avril 2013, 07:07
Thanks Sebastian. What about "minimum" and "maximum?" My "maximum" is set to "39.6" yet the MPS reports 89 Gal/hour (I use gallons, not liters) which sounds about right.
Ce message a été modifié 1 fois. Dernière modification effectuée par "Psychor" (27 avril 2013, 08:57)
samedi 27 avril 2013, 08:56
this is the scale in the lcd when you display the bars.
Psychor
samedi 27 avril 2013, 08:57
Thanks again Sebastian.
