• 16.11.2026, 04:02
New: Digmesa sensor with a 5.6 mm nozzle
mardi 11 septembre 2007, 22:36
We can offer a revised flow sensor in cooperation with Digmesa as of now. This has a modified nozzle with 5.6 mm instead of 3.3 mm. The duct of the sensor is almost identical with that of the tube diameter.
The calibrating value amounts to 256 implulses/l.
The sensor is already in large quantities at the store and the price is identical to the variant with a 3.3 mm nozzle.
heed
Re: New: Digmesa sensor with a 5.6 mm nozzle
vendredi 14 septembre 2007, 08:00
That's great, Shoggy, I might get one (or two) now that there's so much less restriction.
Speaking of that, has AC done any tests to see exactly how much less restrictive it is or how much it can increase flow rate?
drbo
vendredi 14 septembre 2007, 12:16
I did mod my old flowmeter, to these dimentions, and experienced that my flow increased 20%, in a very restrictive system (cpu, mosfet, gpu, nb, 2xram, sb, flowmeter, 2xhdd), using an Aquastream pump ;D
WS: W10 | Asus Rog Strix X299 | i7-7820X | Asus Rog Strix 1080Ti | Dominator 32GB | Corsair 860AXi | 512GB Samsung EVO 970 |WC: EK-Waterblocks | AC- Monitor and Control | 3x EK-CoolStream PE 480 | LD PC-V8
Gamer:W10 | Asus R4E | i7 3930K | 3x Asus HD 7970 CF | Dominator 16GB| Corsair 1200AXi | 2x120GB I520 Raid0 | WC: EK-Waterblocks | AC- Monitor and Control | 4x Airplex PRO 360 | MM Extended Ascension
Top_Nurse
samedi 15 septembre 2007, 18:37
With my use of another brand flow meter, it caused my flow to increase from 80 LPM to about 158 LPM. Roughly a 100% increase in flow.
However, it only made about a 1.5 C difference in system water temps and didn't change my ability to OC my computer hardware at all. I am using a Cuplex XT, two (2) TwinOlex Pro's, and one Asus mosfet block.
