• 22.11.2026, 20:43
mtf
Quick question about the original Aquastream /replacement part.
mercredi 11 septembre 2013, 23:27
Hi all.
I was just looking at getting a new impeller and gaskets for my old school Aquastream and I came across this in the shop:
http://shop.aquacomputer.de/product_info…roducts_id=2289
I was going to order it anyway as it's not costly but I was wondering if it was for the Aquastream?
:thumbsup:
jeudi 12 septembre 2013, 08:49
If you mean the o-ring from the round cover it is this one.
mtf
jeudi 12 septembre 2013, 16:01
No, I don't mean that one. I have the aquastream one in my basket.
Which pump is the gasket set in the OP for?
b0nez
jeudi 12 septembre 2013, 16:44
The Gasket you linked in your first post is for a filter element. The picture is the same but not the O-Ring.
Keep in mind that it's only one O-Ring Shoggy posted, not a Kit. But it's the only one I remember being on a AS.
:rolleyes:
mtf
jeudi 12 septembre 2013, 16:47
Ahh, ok. Is that filter good for the aquastream?
b0nez
vendredi 13 septembre 2013, 17:46
Its a separate filter which you can put into your system - link
:rolleyes:
Discussions similaires
